67 B Body bolt finish #1501894
09/15/13 04:48 PM
09/15/13 04:48 PM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
What is the correct plating/finish on the bolts which are on the panel above the headlights which the hood spring, latch and headlight assemblies are connected to?. It is a 67 Charger.
thanks
Re: 67 B Body bolt finish [Re: hemi67] #1501895
09/15/13 04:53 PM
09/15/13 04:53 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Typically bolts that aren't visible on the outside of the car with hood and doors closed are black phosphate. If you need better info than that you'll need to post pics of each bolt and it's location.
Re: 67 B Body bolt finish [Re: ScottSmith_Harms] #1501896
09/15/13 05:06 PM
09/15/13 05:06 PM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
Thanks Scott;
When you open the hood and look down at the cross brace that goes from fender to fender , it has several 1/4 bolts attached to it for the headlight, grill, hood latch and hood spring mounting.
Having a tough time finding a picture of a survivor to look at.
Re: 67 B Body bolt finish [Re: hemi67] #1501897
09/16/13 02:32 AM
09/16/13 02:32 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Sounds like those are 1/4 in. "body bolts". By definition, body bolts are painted body color. See:
https://board.moparts.org/ubbthreads/show...e=2#Post7372056
The finish from the bolt maker was, as described by amkproducts.com, "S2 Phosphate & Oil (gray - black)".
Phosphate & Oil should be the same as Parkerizing plus oiling, the gun metal finish on military weapons since about WWI. Chemical kits are sold by blacksmithing suppliers and relatively easy to DIY but maybe not economical for a only a few bolts.
Besides, body bolts were typically S2, then painted with body color; therefore the S2 mostly never shows. Better to just clean them up, remove the "oil", and paint them body color, same as was done at the factory. Unpainted S2 bolt heads on painted parts does not look right.
Absolutely everything that was body color, the body shell, all body panels, battery tray, hood hinges, trunk hinges, door hinges, grille valences, etc., were bolted up and painted as a unit, including the bolt heads.
On my car the yoke cross member bracket, hood pop-up spring, hood lock vertical support, and the upper and lower grille panels were all bolted to the car with 1/4" bolts then painted body color.
