Dealer techs:difference between '05 3.5 and '07 3.5? #150179
11/13/08 01:30 PM
11/13/08 01:30 PM
Marion,Indiana
Seth_Jones Offline OP
Marion,Indiana
Salvage yard tells me the interchange book shows '05-'06 3.5's are not compatible with '07 and up.Any techs out there know what the difference is or if just some minor things need swapped from an '05 engine to an '07 engine.I have a chance to buy a known good '07(cheap) to put in an '05 300.
Re: Dealer techs:difference between '05 3.5 and '07 3.5? [Re: Seth_Jones] #150180
11/13/08 03:31 PM
11/13/08 03:31 PM
Indiana
swepty Offline
swepty  Offline
Indiana
Some of those engines were year specific due to the cam gears. If you had the wrong year motor it would hit rev limiter at like 1000 r's. Call your dealer, or since you are in marion, call Button Dodge parts ask for Larry, tell him Nate told you to call give him your vin and see if an 07 will interchange. He'll know why, because he's dealt with it before.
1976 CREW CAB 3/4 ton 4x4 Factory plow and ex Airforce Truck 1986 Power Ram 400hp 360 6" lift 1970 Plymouth custom suburban 318 4" drop 1996 Dodge 1500 360 4wd 3" lift North Central Indiana Mopar Club member
Re: Dealer techs:difference between '05 3.5 and '07 3.5? [Re: swepty] #150181
11/13/08 03:40 PM
11/13/08 03:40 PM
Marion,Indiana
Marion,Indiana
I'm Parts Manager at Mike Anderson Dodge.The part#'s for the heads,cams,and cam sprockets are the same from 05 to 07.Short block part#'s are different though.
