'68-'69 B body question #1501084
09/14/13 09:41 AM
09/14/13 09:41 AM
Rochester, NY
dusterdood Offline OP
Rochester, NY
My brother has a '68 Roadrunner that he's trying to put the column shift back into and a guy near me popped up on craigslist with a steering column from a '69 and I wondered if the wiring is the same? Should bolt right in, correct?
Mike
Re: '68-'69 B body question [Re: dusterdood] #1501085
09/14/13 02:27 PM
09/14/13 02:27 PM
Omaha Nebraska
Brian_wo Offline
Brian_wo  Offline
Omaha Nebraska
It should bolt right in and as far as wiring look at the diagrams on mymopar.com to be sure but my guess is they are the same.
who is that guy?
Re: '68-'69 B body question [Re: Brian_wo] #1501086
09/14/13 03:01 PM
09/14/13 03:01 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
pretty sure 68-69 are the same... 70 is different.
Coming soon!!!!
Re: '68-'69 B body question [Re: Mr.Yuck] #1501087
09/15/13 08:13 AM
09/15/13 08:13 AM
Rochester, NY
Rochester, NY
Thanks guys, I'll let him know.
Mike
Re: '68-'69 B body question [Re: dusterdood] #1501088
09/15/13 10:30 AM
09/15/13 10:30 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1968 with column shift has a neutral safety switch built into the column.
1969 does not
Re: '68-'69 B body question [Re: gtx6970] #1501089
09/15/13 07:21 PM
09/15/13 07:21 PM
Rochester, NY
Rochester, NY
1969 does not
That's good to know!
Mike
