Speedo gear the same for 727 and 833?
#1500939
09/13/13 07:27 PM
09/13/13 07:27 PM
Posts: 13,363 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
That's the question. Actually, it's an 833OD. I think I need a 38 tooth based on my info for the 727. So, will the 833OD take the same speedometer drive gear? Thanks!
Master, again and still
Re: Speedo gear the same for 727 and 833?
[Re: Kern Dog]
#1500941
09/13/13 08:18 PM
09/13/13 08:18 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Ok, I would like to piggy back this post with the following question.
Is the speedo gear for a 518 the same as a 727?
Im changing gear ratios in the Dakota and would like to match the speedo gear if possible.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1500942
09/13/13 09:11 PM
09/13/13 09:11 PM
Posts: 12,528 Western Colorado High Desert
moparmarks
Yes. My 92 Getrac uses the standard Mopar gear as well as my 91 518.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: DaveRS23]
#1500943
09/13/13 10:13 PM
09/13/13 10:13 PM
DaveRS23
Benton, IL.
Cool! Thanks for the quick response.
[Re: hp383]
#1500944
09/13/13 11:53 PM
09/13/13 11:53 PM
Posts: 18,688 Fresno, CA
Jim_Lusk
Fresno, CA
It depends on the year of the trans (really just the housing for the gear and the gear are different) and whether there is a mechanical output of just the electrical...
[Re: Sinitro]
#1500946
09/14/13 09:17 AM
09/14/13 09:17 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
There are at least three different types of speedo gears/housing combos. Two of them will swap as an assembly, one is a stand alone and you cannot swap with the later two styles.
Plus there are special housings for odd ball gear ratios (like 2.45 rear gears) that will not work with other speedo gears.
So the answer is, it depends.
[Re: John_Kunkel]
#1500948
09/14/13 07:22 PM
09/14/13 07:22 PM
DaveRS23
Benton, IL.
Excellent reference. Thank you.
I need the long style like the bottom one in a 38 tooth (blue). Which used to be 2538938, which superseded to 52068060.
Any chance my local dealer can get one? Or is Brewer's my only real choice? I hate the thought of giving $50+ shipping off ebag for one.
