The wife just got a new Chrysler 200. She likes the Factory fitted splash guards. They mount using 2 existing wheel lip screws but you need to drill a hole in the bottom of the body for a 3rd mounting screw. I have heard 3 ways to prevent rust starting around the drilled hole. 1.Paint the hole with touch up paint & insert screw. 2.Paint the hole with touch up paint & apply silicone liberally to seal everything. 3.Paint the hole with touch up paint & apply loctite liberally to seal everything. I intend to replace the 3rd screw with stainless steel. Which of the 3 is best or, is there a 4th way?
