Polishing Valve Cover? #1500332
09/12/13 12:18 AM
09/12/13 12:18 AM
ONTARIO,CANADA
604 Hemi GTX Offline OP
ONTARIO,CANADA
Who would you guys recommend to polish a set of aluminum valve covers? I would like to get my fabricated covers polished.
Thanks for any and all info
Kevin
How big of a job is it to do it yourself?
Re: Polishing Valve Cover? [Re: 604 Hemi GTX] #1500333
09/12/13 02:14 AM
09/12/13 02:14 AM
I bought a cheap 3/4 Hp Harbor Frieght bench buffer , I wish that I had bought a better one now like a Baldor or Central brand bench buffer I bought some polishing compound and applied it to the wheels and followed the instructions for the compound and start buffing the sides of a set of cast M/T BB valve covers, they shine now Buy a book on polishing and think about what you want to do,take your time and look at the results Do you want the welded seams to shine If so grind and sand them down and then polish them and go from there
Re: Polishing Valve Cover? [Re: 604 Hemi GTX] #1500334
09/12/13 07:52 AM
09/12/13 07:52 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
It's a 5 minute job by hand per valve cover. Use any kind of metal polish or wheel polish. You don't even have to take them off. Use your hands...might break a sweat.
Re: Polishing Valve Cover? [Re: 604 Hemi GTX] #1500335
09/12/13 07:58 AM
09/12/13 07:58 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Polish whaaaat?
Re: Polishing Valve Cover? [Re: Dragula] #1500336
09/12/13 08:28 AM
09/12/13 08:28 AM
Cincinnati, Ohio
Cincinnati, Ohio
I have mag valve covers on my hemi, they need to be polished every 3rd day. They have been polished hundreds of times.
Nice looking peice of hardware you have there!!
Re: Polishing Valve Cover? [Re: Challenger 1] #1500337
09/12/13 12:20 PM
09/12/13 12:20 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I would not grind the welds smooth,if a good weld no problem,but they can be thin spots in the weld as well as pin holes!Even the best of welders,welding all day long tend to get a little slack at times,and the robot welders that a lot of the bigger companies use and even some of the smaller ones are slack all the time.
PS Even you when grinding could take just a little to much off!
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Polishing Valve Cover? [Re: 604 Hemi GTX] #1500338
09/12/13 06:24 PM
09/12/13 06:24 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Depending on the finish, it could be a big job. Send them to me, i'll make them look like chrome.
Re: Polishing Valve Cover? [Re: rickraw] #1500339
09/12/13 07:17 PM
09/12/13 07:17 PM
ONTARIO,CANADA
ONTARIO,CANADA
So when do you want them and that's what I want them to look like.
Kevin
Re: Polishing Valve Cover? [Re: 604 Hemi GTX] #1500340
09/12/13 10:45 PM
09/12/13 10:45 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Had mine done by the local wheel fix it guy
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Polishing Valve Cover? [Re: rickraw] #1500341
09/12/13 10:55 PM
09/12/13 10:55 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I'm polishing a set of centerline wheels that were bead blasted and painted,yuck. Actually "polishing" them is way down the list of steps to bring them back.Lot's of work if you want it done correctly.
Re: Polishing Valve Cover? [Re: goldmember] #1500342
09/13/13 10:13 AM
09/13/13 10:13 AM
Cincinnati, Ohio
Cincinnati, Ohio
I don't see how they can be brought back if they were bead blasted.
Polishing stuff is really easy and very rewarding. It can be done by hand or you can invest a small amount of money and buy a cotton buff to put on yout drill. Valve covers are one of the easiest things to polish imo.
Re: Polishing Valve Cover? [Re: Challenger 1] #1500343
09/13/13 02:07 PM
09/13/13 02:07 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Polishing an already polished surface that needs little to to brought back to acceptable(for most) is easy. That's not the case when an item has either a finish(brushed,glass beaded,pits,scratches,etc)there is a BIG difference in the process needed to refinish(not polish) a surface in other conditions. Yes, refinishing wheels that have been glass bead blasted is NOT a first timer deal and if I didn't have 20plus years refinishing metals I'd be much better off starting with a new set of wheels. I'll have 8 hours or a bit more in doing 4 wheels. The first step is not whipping out the polish,it's looking the item over to decide the best first step.
Re: Polishing Valve Cover? [Re: goldmember] #1500344
09/13/13 02:18 PM
09/13/13 02:18 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I had polished up my valve covers. Lots of work but looked awesome. That lasted less then one year. The were a major problem pain to keep nice. They are now powder coated.
That being said, I still wanted the polished look on some parts. Polished my air tube and air bonnet. I then had them powder coated clear over top. They have stayed very nice, and I would highly recommend it.
Re: Polishing Valve Cover? [Re: dizuster] #1500345
09/13/13 02:20 PM
09/13/13 02:20 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
pic 1
Re: Polishing Valve Cover? [Re: dizuster] #1500346
09/13/13 02:23 PM
09/13/13 02:23 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Powder Coated Valve Covers
Clear Powder Coated Air Tube/Hat
Re: Polishing Valve Cover? [Re: dizuster] #1500347
09/13/13 07:20 PM
09/13/13 07:20 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Yep,any uncoated aluminum is going to require work to keep up. Your engine looks great,just don't do the exterior to match.
Re: Polishing Valve Cover? [Re: goldmember] #1500348
09/13/13 07:38 PM
09/13/13 07:38 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
LOL... no worries... outside of the car is safe.
Re: Polishing Valve Cover? [Re: 604 Hemi GTX] #1500349
09/14/13 10:29 AM
09/14/13 10:29 AM
hiding in illinois
slax69gts Offline
slax69gts  Offline
hiding in illinois
last year i picked up for cheap a set of alu finned cal customs that were pitted. by hand and time i used 220 grit to smooth them out then finished them with green scotch brite pad and sealed with carnuba wax. since my 470 has mostly alu components i needed some color up top so i painted inside the fins street hemi orange to match the block. they look great.
