8 3/4 bolts #149980
11/13/08 12:53 AM
11/13/08 12:53 AM
Missouri
Confusedcuda Offline OP
Missouri
Does anybody know what size of bolts you use to connect the differential to the housing on my A-body 8 3/4 rear. What kind of gear oil is everybody using and how much? Thanks
Re: 8 3/4 bolts [Re: Confusedcuda] #149981
11/13/08 12:57 AM
11/13/08 12:57 AM
OK
70SWGR Offline
70SWGR  Offline
OK
Are the studs missing in that housing?
I was told to use walmart supertech 75-140 and either the mopar or ford friction modifier.
Re: 8 3/4 bolts [Re: Confusedcuda] #149982
11/13/08 12:58 AM
11/13/08 12:58 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Yep, as mentioned they are studs in the housing with nuts....
If you are missing them, give DrDiff a holler
Re: 8 3/4 bolts [Re: OzHemi] #149983
11/13/08 01:52 AM
11/13/08 01:52 AM
Missouri
Missouri
Dr. Diff?
Re: 8 3/4 bolts [Re: Confusedcuda] #149984
11/13/08 01:57 AM
11/13/08 01:57 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
he's a member here.
do a member search. he sells nothing but rear ends and rear end parts!
**Photobucket sucks**
Re: 8 3/4 bolts [Re: Confusedcuda] #149985
11/13/08 10:53 AM
11/13/08 10:53 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
As said there are studs pressed into the housing , they are 3/8-24
Re: 8 3/4 bolts [Re: JohnRR] #149986
11/13/08 10:55 AM
11/13/08 10:55 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
And yes use the Walmart - SuperTech 75-140 and the Ford Racing Friction modifyer (get at Ford dealer). I am sure you will here all different opinions about this but this is the way to go.
Re: 8 3/4 bolts [Re: Cuda340] #149987
11/13/08 11:23 AM
11/13/08 11:23 AM
JohnRR Offline
JohnRR  Offline
I don't shop at wal mart so is there an alternative ?
Re: 8 3/4 bolts [Re: JohnRR] #149988
11/13/08 11:33 AM
11/13/08 11:33 AM
scratchnfotraction Offline
napa brand oils for me
I like the straight 30wieght oil napa brand
I use there gear oil as well 90-140
I dont wally world ether
napa has those studs in the dorman fastner catalog also
