Page 3 of 13 1 2 3 4 5 12 13
Re: 37 Plymouth PU Ressurection. [Re: RodStRace] #1499049
09/21/13 12:28 PM
09/21/13 12:28 PM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
http://www.fordstrokers.com/break-in/
BUT you MUST ALWAYS prime the oil pump mechanically before starting your new engine for the first time. If you do not own an oil pump shaft priming tool, you can easily use a 1/4 inch extension with a 1/4 inch socket taped to the extension and chucked in your drill. Proceed to spin the drill counterclockwise for 15-20 seconds, rotate the engine 1/4 turn, continue to run the drill again for another 15-20 seconds and turn the engine over by hand another 1/4 turn. Do this until you have turned the engine over a full revolution AND you have oil at all pushrods.
Thanks for the help
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499050
09/21/13 07:56 PM
09/21/13 07:56 PM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
Re: 37 Plymouth PU Ressurection. [Re: Hotwheelsjr] #1499051
09/21/13 09:11 PM
09/21/13 09:11 PM
Dreaming of the 808
Dreaming of the 808
She runs! A little teaser...
http://smg.photobucket.com/user/hotwheelsjr/media/Cars/VIDEO0015_zps9874f86d.mp4.html
Thanks for the help Mike, also a big thank you to Jim aka 65Belve and Dave, tomorrow I tackle the rear end and leaf springs
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499052
09/21/13 09:57 PM
09/21/13 09:57 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Anytime Dave. Glad to help you move forward on the old rig.
Thanks for lunch
Re: 37 Plymouth PU Ressurection. [Re: nomore65BelvJim] #1499053
09/21/13 11:08 PM
09/21/13 11:08 PM
Hotwheelsjr Offline
Hotwheelsjr  Offline
Thanks for lunch
Re: 37 Plymouth PU Ressurection. [Re: nomore65BelvJim] #1499054
09/22/13 01:23 AM
09/22/13 01:23 AM
Dreaming of the 808
Dreaming of the 808
Thanks for lunch
My pleasure to buy you guys lunch, it was great catching up as well
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499055
09/22/13 10:35 AM
09/22/13 10:35 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
And another
I've always liked this truck...glad to see you working on it.
Moparlee
Re: 37 Plymouth PU Ressurection. [Re: Robbins] #1499056
09/22/13 05:19 PM
09/22/13 05:19 PM
Dreaming of the 808
Dreaming of the 808
And another
Thank you, plugging away at it today.
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499057
09/22/13 05:22 PM
09/22/13 05:22 PM
Dreaming of the 808
Dreaming of the 808
Got the rear suspension (aka caveman 4 link) stripped out and the rear end grinded and prepped for new correct spring perches. All this metal is destined for the recycle bin.
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499058
09/22/13 05:24 PM
09/22/13 05:24 PM
Dreaming of the 808
Dreaming of the 808
Plastic to contain the grinding sparks
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499059
09/22/13 09:40 PM
09/22/13 09:40 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
A leaf blower works better once you are done.
Re: 37 Plymouth PU Ressurection. [Re: moparpollack] #1499060
09/23/13 01:28 AM
09/23/13 01:28 AM
Dreaming of the 808
Dreaming of the 808
I was trying to not throw sparks on my other vehicles parked next to it.
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499061
09/23/13 01:33 AM
09/23/13 01:33 AM
Dreaming of the 808
Dreaming of the 808
Side by side of rear springs, I removed 4 of the 9 leafs since I am putting the axle on top and don't need the extra leafs hanging down.
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499062
09/23/13 07:32 AM
09/23/13 07:32 AM
AZ
Mike P Online content
Mike P  Online Content
AZ
I'll be interested to see how this works out. Like you, someone got to my rear suspension and pretty much hosed it up. I've been working on cars for more years than I care to admit to and some folks "fixes" still amaze me.
When I finally get back on mine, I'm going yo try to use some later passenger car springs and hanger I have laying around.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: 37 Plymouth PU Ressurection. [Re: Mike P] #1499063
09/23/13 02:33 PM
09/23/13 02:33 PM
Dreaming of the 808
Dreaming of the 808
Springs are in the shop being de-arched 3 inches
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499064
09/25/13 12:26 AM
09/25/13 12:26 AM
Dreaming of the 808
Dreaming of the 808
New reproduction running boards came today, they look perfect made of 14 gauge steel
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499065
09/25/13 12:28 AM
09/25/13 12:28 AM
Nice
Re: 37 Plymouth PU Ressurection. [Re: ] #1499067
09/25/13 09:56 AM
09/25/13 09:56 AM
AZ
AZ
Those do look nice, are you planning on painting or covering them like the originals?
Re: 37 Plymouth PU Ressurection. [Re: ] #1499068
09/25/13 11:23 AM
09/25/13 11:23 AM
Dreaming of the 808
Dreaming of the 808
where did you find them?
Do they make a set for 4 door's sedans?
I found them on eBay, a little over $500.00 shipped to my door, not sure about other cars
Re: 37 Plymouth PU Ressurection. [Re: Mike P] #1499069
09/25/13 11:24 AM
09/25/13 11:24 AM
Dreaming of the 808
Dreaming of the 808
Mike, I'm not sure what I will do yet, maybe Rhino Lining
