Does anyone make this?
#149854
11/12/08 06:19 PM
11/12/08 06:19 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I'm looking for a plug/block off for my 727 where the speedo cable would go. I put a freeze plug in it but it leaks and I'm tired of it. Anyone make something like this?
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Does anyone make this?
[Re: Jacob Pitt]
#149855
11/12/08 06:37 PM
11/12/08 06:37 PM
RapidRobert
some types of freeze plugs are deeper than others. "Dorman" brand is good.
[Re: RapidRobert]
#149856
11/12/08 06:47 PM
11/12/08 06:47 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
i used the deep freeze plugs with RTV coated around it.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Jacob Pitt]
#149858
11/12/08 07:15 PM
11/12/08 07:15 PM
Posts: 10,560 Rittman Ohio
fourgearsavoy
Rittman Ohio
Look in the boneyards for an older International 4X4 truck trans/transfer assy.They have a trick speedo adapter with a cap on it.I have one in my toolbox at work leftover from my Mopar 4-speed transmissions.I will take a pic if I remember. Gus ![](/ubbthreads/images/graemlins/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#149859
11/13/08 07:58 AM
11/13/08 07:58 AM
Jacob Pitt
Mansfield, Tx
It would be sweet if someone would make a billet aluminum block off with an o-ring. They would sell a bunch of them.
[Re: Scott Carl]
#149861
11/13/08 02:00 PM
11/13/08 02:00 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
I used a rubber one. The kind that you turn the nut in the center and it expands in the hole. Never leaked as long as I had it. 5 or 6 years.
With the metal washer behind the nut, when in place, that's all you see; a round metal plate with a nut in the center. Cheap, perfectly sealed, easily removed (if you ever need to) and rather clean looking IMHO. Paint it the color of your tranny if painted, or leave the bright zinc finish ![](/ubbthreads/images/graemlins/thumbs.gif)
