Re: Best way to package center chunk for shipping?
[Re: Neil]
#149804
11/12/08 04:36 PM
11/12/08 04:36 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
Big plastic bucket.
With the lid wired on . Something stiff , like a piece of 1/2" or 3/4" inch plywood in the bottom and LOTS of packing , put the chuck itself in a plastic bag and INSURE it .
[Re: JohnRR]
#149805
11/12/08 04:48 PM
11/12/08 04:48 PM
Posts: 2,370 Wheatfield, NY
Cuda340
Wheatfield, NY
Big plastic bucket.
5 gallon bucket and the rest of what John said.
[Re: dOc !]
#149807
11/12/08 05:11 PM
11/12/08 05:11 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I've shipped two this year (WA to FL). Plastic bucket, Pile-O- Shop Rags in the bottom to soften the ring gear on a cushion of rags, place plastic bucket inside a steel bucket of similar size, cover top and bottom with wood or whatever is handy that is stiff and supportive, stick a GOOD label on BOTH buckets, then wrap the entire mess in cardboard, tape well, add 3rd label to cardboard. Both made it with zero issues, FED EX Ground was cheapest.
[Re: dOc !]
#149808
11/12/08 05:14 PM
11/12/08 05:14 PM
Posts: 15,487 Florida
scratchnfotraction
I used a milk crate zip tied it in there,the yoke poked up out of the corner a little I wraped it in plastic shrink wrap and cut a cardboard box up and taped it all around it stuck the addy on a sent it to ARK...cost about 40 bucks should have seen the ups lady throw it over her head on to a slid table to go out to the warehouse the 2 liter bolt holders work good for pistons and rods storage also,they come with 8 holes
[Re: scratchnfotraction]
#149809
11/12/08 06:13 PM
11/12/08 06:13 PM
340dart4spd
Parts Problem
Parts Problem
I used a milk crate
80 plus pound and you shipped it for 40 bucks must have been 1970
[Re: rrunner]
#149811
11/12/08 07:31 PM
11/12/08 07:31 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Worst thing to get is something packed with loose newspaper come to your door. Make sure there is no movement in the container you are using after packing. remember... NO MOVEMENT IN THE BOX!
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: 85_Ram_4speed]
#149813
11/13/08 01:48 AM
11/13/08 01:48 AM
Posts: 2,886 US of A
A38s!
US of A
I shipped one up to ID. Went to Wallymart, bought a plastic cooler ($15 bucks?). Sat inside just perfect. Zipped tied lid down. Slapped the label on it. Worked excellent. Beats fartin around.
WANTED: Your 71-78 Late B-body sedan parts! Police or Civilian.
