Re: RicerCuda build update
[Re: Skeptic]
#1497695
09/07/13 03:46 PM
09/07/13 03:46 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Get-sum! I may have a 6.1 in the works for my A-body, then ill be back wear you are, trippin over hoists, creepers, pieces of wood etc.
Mopar to the bone!!!
[Re: PHJ426]
#1497700
09/07/13 09:50 PM
09/07/13 09:50 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
Here is a thread that I started about the build. Short story, stock stroke 400" B engine, small Comp thumper cam, mildly ported RPM heads 1.6:1 PRW stainless rockers, Road Race pan, crank scraper, Offy tunnel ram, 2 AVS carbs, Jegs MP knockoff distributor. 472 HP @ 5300, 489 ft/lbs @ 4700.
[Re: Skeptic]
#1497703
09/08/13 12:19 AM
09/08/13 12:19 AM
Posts: 27,480 So Cal
autoxcuda
So Cal
Hi Steve I took today off, I've had this last week off from work, so I thrashed during one of the hottest weeks of the year Tomorrow I put the motor mount bolts in, install the radiator/fan, starter, flexplate-> converter bolts, run fuel lines and mount carbs. Oh ya, clean up my Dad's garage and driveway. I think I'm going to stick with the 255/50s I like the Nitto INVO tires to replace the current skins.
Bummer timing on the weather.
Now that it's cooled off some, I'm going to put on a master cylinder.
[Re: autoxcuda]
#1497706
09/09/13 11:11 PM
09/09/13 11:11 PM
Skeptic
The Pale Blue Dot
So how'd that go? Are you upgrading the brakes or just replacing it.
[Re: Skeptic]
#1497708
09/10/13 02:03 AM
09/10/13 02:03 AM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Skeptic -- you mentioned switching to a maual valve body (automatic trans)... I beleiev when that done, it takes away the allowance to manually downshift at your discretion.. if that occurs, uts not good.. since you want to be able to up shift/down shift at any speeds/rpms for autocrossing/road course events... I suggest that you double-check that situation before you'd regret it.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: 67autocross]
#1497709
09/10/13 11:15 AM
09/10/13 11:15 AM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
Are you going to road race/ autocross a car with a tunnel ram! Has this been done before?
Sort of. The cross rams made popular by the Z28 302 were essentially tunnel rams flattened to fit under the hood line mandated by SCCA for the trans am series, so I'd say they work pretty good.
Despite the popular reputation of them, tunnel rams actually make more power under the curve, across the entire power band than any other intake. Many moons ago Hot Rod did a manifold shoot out on a 383 using a couple dozen single and dual plane intakes along with a couple of tunnel rams thrown in for grins. Net result was the tunnel rams kicked butt on everything in horsepower AND torque.
I've got a Weiand High Ram and a couple of Holley 450s that I'm going to throw on my heap after I baseline it all with the Air Gap and 750.
[Re: TC@HP2]
#1497710
09/10/13 11:24 AM
09/10/13 11:24 AM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
I guess there is really no reason that it won't work if it is set up well, I wonder what it will be like when you exit a corner hard and get on the gas, might be a bit of a pain to get set up for this. When you do show up a the track it will draw a crowd that for sure.
A new iron curtain drawn across the 49th parallel
[Re: 67autocross]
#1497711
09/10/13 03:05 PM
09/10/13 03:05 PM
Mopar Mitch
The downfall of such a setup (multiple carbs, tunnel ram, etc) is the weight. Less weight up front is what's desired... even a s/b six pack setup weighs 60 lbs vs the 30 lbs of an aluminum 4 bbl setup... thats 30 pounds removed from the car, removed from the FRONT end where the weight is NOT wanted. Running such multi-carb setups may look cool, but they'll actually slow down the car through its pace around an autocross course. Unless the car will be run wide-open throttle on lengthy road courses, a lighter-weight single 4-bbl setup will have better advantages all through the corners/curves/turns, better deceleration, and to some extent better acceleration. The races are won in the turns, not the straights.
Mopar Mitch
[Re: Mopar Mitch]
#1497713
09/10/13 10:37 PM
09/10/13 10:37 PM
Posts: 22,721 Bitopia
jcc
Bitopia
Mitch, but it looks really cool. And its like the highest point on the engine.
