1969 Plymouth B body floor pan
#1497473
09/07/13 12:13 AM
09/07/13 12:13 AM
Posts: 34,974 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Can you get it as once piece , instead of using 4 seperate pieces
Or is it easier to install in 4 ?
How many hours would one expect to remove / replace a complete floor
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 1969 Plymouth B body floor pan
[Re: bigdad]
#1497475
09/07/13 02:12 AM
09/07/13 02:12 AM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Can you get the full pan in the car without hacking? Will it fit through the side window and door opening on a hardtop or does the windshield need to come out?
You can't slip it in from the bottom due to the frame rails running under it.
[Re: bigdad]
#1497477
09/07/13 10:28 AM
09/07/13 10:28 AM
Posts: 21,534 It's a dry heat
gtx6970
It's a dry heat
Its a wagon
The B pillar is going to create a problem getting it in from the side. might try windshield removal. If thats a no go split it down the middle and reweld it back together
