OEM Cast Iron HEMI Cylinder heads: Flow Numbers #1497320
09/06/13 06:21 PM
09/06/13 06:21 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I just got the flow numbers for my OEM cast iron HEMI cyl heads going on my original 69 HEMI charger....
Just a good valvejob and NO PORTING.
What do you guys think? HP potential????
Re: OEM Cast Iron HEMI Cylinder heads: Flow Numbers [Re: domingo] #1497321
09/06/13 07:12 PM
09/06/13 07:12 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Why did they stop at .500 lift???? I use stock iron heads also
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: OEM Cast Iron HEMI Cylinder heads: Flow Numbers [Re: hemi-itis] #1497322
09/06/13 07:17 PM
09/06/13 07:17 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Because this is for a pure stock build!
Re: OEM Cast Iron HEMI Cylinder heads: Flow Numbers [Re: domingo] #1497323
09/06/13 07:31 PM
09/06/13 07:31 PM
hemi-itis Offline
hemi-itis  Offline
Good luck with your quest,I was never able to leave anything "stock"
Re: OEM Cast Iron HEMI Cylinder heads: Flow Numbers [Re: hemi-itis] #1497324
09/06/13 07:51 PM
09/06/13 07:51 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Pure stock HEMI cars run in the 11s!!!!!
Stock stroke, stock cam specs, no porting, full exhaust, I believe 11:1 max compression, stock tires.
Re: OEM Cast Iron HEMI Cylinder heads: Flow Numbers [Re: domingo] #1497325
09/06/13 08:12 PM
09/06/13 08:12 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Pure stock engines that run faster than they did when new are built to NHRA specs , I don't know the specs on a hemi but it wouldn't surprise me to see the compression closer to 12.0 vs. the factory advertised 10.25
Re: OEM Cast Iron HEMI Cylinder heads: Flow Numbers [Re: JohnRR] #1497326
09/06/13 08:26 PM
09/06/13 08:26 PM
Pure stock and Factory stock allow 1.5 points higher for compression ratio over stock advertised. So, a street hemi can legally go up to 11.75:1.
Re: OEM Cast Iron HEMI Cylinder heads: Flow Numbers [Re: ] #1497327
09/06/13 08:39 PM
09/06/13 08:39 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Yes, 11,7:1 that is right.
Re: OEM Cast Iron HEMI Cylinder heads: Flow Numbers [Re: domingo] #1497328
09/06/13 08:42 PM
09/06/13 08:42 PM
NY
F1Scamp Offline
F1Scamp  Offline
NY
Boy I guess that's why I feel like anybody running a Hemi is taking the easy way out...
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
Re: OEM Cast Iron HEMI Cylinder heads: Flow Numbers [Re: domingo] #1497329
09/06/13 08:42 PM
09/06/13 08:42 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Pure stock HEMI cars run in the low 10s!!!!!
Fixed that for you...
Re: OEM Cast Iron HEMI Cylinder heads: Flow Numbers [Re: hemi-itis] #1497330
09/06/13 10:50 PM
09/06/13 10:50 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
I'm the same way! It is physically impossible for me to leave anything bone stock.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: OEM Cast Iron HEMI Cylinder heads: Flow Numbers [Re: domingo] #1497331
09/06/13 10:53 PM
09/06/13 10:53 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Why do you South Americans use commas in the wrong places? J/K
Re: OEM Cast Iron HEMI Cylinder heads: Flow Numbers [Re: DusterDave] #1497332
09/06/13 10:57 PM
09/06/13 10:57 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Thats why Im in a struggle with myself on wether leaving it stock stroke or using the 4.15 stroker kit I have on the shelf....
I wont be able to use 11.7:1 compression because gasoline down here is CRAPPY.
I would be limited to run only up to 10:1 with the cast iron heads and the local pump gas....
My stroker kit will yield just shy of 10:1
Re: OEM Cast Iron HEMI Cylinder heads: Flow Numbers [Re: domingo] #1497333
09/07/13 10:34 PM
09/07/13 10:34 PM
dogdays Offline
dogdays  Offline
I'm going to try to make this simple. Your stock head flow numbers are good for at least 700 hp.
Getting 700 hp from a naturally aspirated 426 requires rpm in the stratosphere. You pay out the nose for valvetrain, etc.
The 426 was the direct result of NASCAR's 7-liter rule.
So they made the best heads they could, but the displacement was limited by the rule. Result is an engine with way too much cylinder head for its size.
You don't have a 7 liter rule. Build the biggest shortblock you can afford. Then it'll make the hp at a more usable rpm.
It just makes sense.
R.
Re: OEM Cast Iron HEMI Cylinder heads: Flow Numbers [Re: dogdays] #1497334
09/08/13 09:05 AM
09/08/13 09:05 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
R.
Yes that is totally right, only thing is I might consider the idea of shipping this car over to the states so I can keeo it there and Id love to participate in the pure stock drags...it would be killer.
Now on the other hand....
Yes, if I were to keep it here what makes the most sense is just to build it for pump gas use and put a 4.15 stroker kit in it.....which I already have, for a compression just shy of 10:1
decisions, decisions, decisions.....
Re: OEM Cast Iron HEMI Cylinder heads: Flow Numbers [Re: domingo] #1497335
09/08/13 12:35 PM
09/08/13 12:35 PM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Hemi heads have a tendency of doing well in a flow bench, however it seems to be way more difficult to get out power that equals the flow capacity.
Whatkind of gas you have over there, how is it rated?
Plynouth VIP '67 TT IC EFI
Re: OEM Cast Iron HEMI Cylinder heads: Flow Numbers [Re: jyrki] #1497336
09/08/13 12:48 PM
09/08/13 12:48 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
We have 98 octane, but it is actually a (RON+MON)/2 rating.
I would say it is equivalent to 92 octane US pump Gas. In the USA I think they only use RON ratings.
I dont have that figured out yet....
This is the main thing that might make me consider not running a 11.7:1 compression ratio.
We have aviation gasoline available and that ones is 100 octane.
I can add lead additive (liqui Moly) and that should help some, and I want to find out about toluene, I think I can get it locally and blend it with out gasoline to raise the octane level, and I think some people do it here.....but I still havent researched that much. I dotn know what it takes...
Re: OEM Cast Iron HEMI Cylinder heads: Flow Numbers [Re: domingo] #1497337
09/08/13 01:11 PM
09/08/13 01:11 PM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
So you have it rated the same way as here. We had over 12:1 agt best, but the cams had pretty huge degrees adn other things were decently scienced out too. Since it's not practical to go overboard I would keep teh CR "safe" and choose the other parts, mainly the cam, accordingly. If you want more detonation resistance, add 5-10% toluene to your gas!
Re: OEM Cast Iron HEMI Cylinder heads: Flow Numbers [Re: jyrki] #1497338
09/08/13 01:40 PM
09/08/13 01:40 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Will toluene harm engine components or is it safe to use????
I think aviation gasoline is a true 100 octane rating....I may be able to buy a drum and keep it at the shop probably...
