which epoxy? JB weld or ? #1497074
09/06/13 12:02 PM
09/06/13 12:02 PM
RapidRobert Offline OP
oil pickup mods. What do you recommend I use? Thank you for your time.
Re: which epoxy? JB weld or ? [Re: RapidRobert] #1497075
09/06/13 03:01 PM
09/06/13 03:01 PM
dogdays Offline
dogdays  Offline
I'm wondering why you are using epoxy at all. Please explain.
R.
Re: which epoxy? JB weld or ? [Re: RapidRobert] #1497076
09/06/13 06:24 PM
09/06/13 06:24 PM
MN
astrobuf Offline
astrobuf  Offline
MN
Do not leave epoxy exposed to oil, it will eventually swell and dislodge/debond. Why would you want to use an epoxy with a vibrating oil pump.
Astrobuf
So, are you really a Rocket Scientist?
Re: which epoxy? JB weld or ? [Re: RapidRobert] #1497077
09/06/13 09:12 PM
09/06/13 09:12 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
gas weld it.
Re: which epoxy? JB weld or ? [Re: ek3] #1497078
09/09/13 11:43 AM
09/09/13 11:43 AM
OK, I will have it gas welded
Re: which epoxy? JB weld or ? [Re: RapidRobert] #1497079
09/09/13 05:06 PM
09/09/13 05:06 PM
MN
astrobuf Offline
astrobuf  Offline
MN
be careful, it's quite difficult to gas weld cast iron. You might be better to braze the tube into the body. Less heat and less risk.
http://www.toolsandgarages.com/index.php?topic=839.0
Astrobuf
Re: which epoxy? JB weld or ? [Re: astrobuf] #1497080
09/09/13 05:18 PM
09/09/13 05:18 PM
pennsylvania
poboyengineering Offline
pennsylvania
Astrobuf
links like this are why I keep coming back! thanks so much..
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: which epoxy? JB weld or ? [Re: poboyengineering] #1497081
09/10/13 01:47 AM
09/10/13 01:47 AM
E
ek3 Offline
ek3  Offline
E
I Meant braze..to many old timers around here called it torch welding and would say gas welding is the only real and true way to weld anything. old habits
Re: which epoxy? JB weld or ? [Re: RapidRobert] #1497082
09/10/13 02:35 AM
09/10/13 02:35 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Pickup tubes are easy to mig or tig weld. I wouldn't think of a jb weld patch on on something that critical.
Re: which epoxy? JB weld or ? [Re: dogdays] #1497083
09/10/13 03:36 AM
09/10/13 03:36 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
R.
Re: which epoxy? JB weld or ? [Re: astrobuf] #1497084
09/10/13 06:44 AM
09/10/13 06:44 AM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
Astrobuf
Vibrating oil pump? It would seem If you have harmonics that severe his pick up would be the least of his worries.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: which epoxy? JB weld or ? [Re: BB65Barracuda] #1497085
09/10/13 09:15 AM
09/10/13 09:15 AM
MN
astrobuf Offline
astrobuf  Offline
MN
Astrobuf
An oil pump is a bit like a tuning fork. The pickup is flexible and has mass on the end. Take a hammer and bang on an oil pump, you'll see the pickup wiggle, especially at its resonant frequency. The engine firing pattern does the hammering.
Astrobuf
Re: which epoxy? JB weld or ? [Re: astrobuf] #1497086
09/10/13 10:08 AM
09/10/13 10:08 AM
MICHIGAN
MICHIGAN
Astrobuf
Astrobuf
Hmmm! You sure sound convincing.
Re: which epoxy? JB weld or ? [Re: BB65Barracuda] #1497087
09/10/13 10:16 AM
09/10/13 10:16 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Astrobuf
Astrobuf
I have broke off the entire oil pump from a BB chevy more than once from tire shake. They make a brace to keep it from happening, I fixed it for good by going with a belt driven external pump.
When you start making power you learn about these things.
Re: which epoxy? JB weld or ? [Re: Challenger 1] #1497088
09/10/13 10:26 AM
09/10/13 10:26 AM
MICHIGAN
MICHIGAN
Astrobuf
Astrobuf
I agree with the tire shake issue, That is an effect from outside the engine.
Im just not sure about the comparison of Banging on the case of a oil pump with a Hammer and resonant Harmonics from an oil pump operating as intended.
Re: which epoxy? JB weld or ? [Re: BB65Barracuda] #1497089
09/10/13 11:09 AM
09/10/13 11:09 AM
MN
astrobuf Offline
astrobuf  Offline
MN
Astrobuf
Astrobuf
Trust me, I'm a Mechanical Engineer with an extensive background in structural mechanics ;p
Re: which epoxy? JB weld or ? [Re: astrobuf] #1497090
09/10/13 12:46 PM
09/10/13 12:46 PM
dogdays Offline
dogdays  Offline
So am I.
To the disbelievers, there is A REASON why Chrysler supported the end of the pickup tube by placing it on the floor of the oil pan.
But if you don't want to learn or understand, there's no help for you.
R.
Re: which epoxy? JB weld or ? [Re: dogdays] #1497091
09/10/13 01:30 PM
09/10/13 01:30 PM
MICHIGAN
MICHIGAN
Sorry I'm just a lowly Electrical Engineer.
Your intellect is obviously far superior to my own.
I bow down before you!
I'm pretty sure most all of the manufacturers support or have a distance they keep the pickup of the bottom of the pan so it stays submerged in the oil.
Im pretty sure it is not recommended to set the pickup directly on the floor of the oil pan.
Re: which epoxy? JB weld or ? [Re: dogdays] #1497092
09/10/13 01:34 PM
09/10/13 01:34 PM
MN
astrobuf Offline
astrobuf  Offline
MN
So am I.
R.
It is indeed a much better design (as is usual for Chrysler) than the GM configuration where most of the experience with brazing the pickup was developed.
I think this discussion started with the question of gluing the pickup in for reinforcement, a bad idea no matter what the design given the heat and oil exposure.
Astrobuf
Re: which epoxy? JB weld or ? [Re: BB65Barracuda] #1497093
09/10/13 02:31 PM
09/10/13 02:31 PM
BDW Online content
BDW  Online Content
Don't you dare apologize, everyone knows mechanical engineers are the ones who couldn't cut it in the EE dept.
Bazinga!
