You should still use the factory gauge fusible link which is 16ga...regardless of the alternator output. The fusible link is there to protect all the wiring in your car (especially the well-known ammeter) from melting down due to a
prolonged high charge/discharge situation. This would be something like a melted/shorted wire. Also since the rest of the wiring in the car (assuming stock here) is only rated for so many amps, I wouldn't 'up' the link size as it wouldn't adequately protect the wiring from burning up. If you are adding additional electrical loads (WP/fuel pump/fans/etc), pull them directly from the alternator stud which will in effect, bypass all the wiring when the car is running.
Yeah, you could use a standard fuse but it will blow almost immediately if there is a short spike on the charging circuit which WILL most likely happen and shouldn't be cause for concern aka right after cranking for a while and trying to recharge a depleted battery.
There is a reason the factory didn't use standard fuses...
I could see maybe getting a
higher rated fuse (75 amp+) and putting that in-line with the fusible link as a secondary fuse but I don't really see a significant benefit here. The factory knew that these cars would have short term hi-current draws that couldn't be sustained for the long term but were a fact...that's why they used the fusible link.
![](/ubbthreads/images/graemlins/thumbs.gif)
