carter carburetor help
#1496340
09/04/13 08:09 PM
09/04/13 08:09 PM
Posts: 162 MA.
plymguy
MA.
I recently bought a 318 engine from a 1972 Plymouth Satellite to put into my '67 Fury. Ont the top of the carburetor there is a port that I have no idea what it is for or where it connects to. Any help will be greatly appreciated. John [image] ![](http://i6.photobucket.com/albums/y202/plymguy/carb1A.jpg) [/image]
Re: carter carburetor help
[Re: superwrench]
#1496344
09/05/13 01:30 PM
09/05/13 01:30 PM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
Do NOT block it off...that's your atmospheric vent to the bowl. If anything, just leave it as it is.
Yup, just leave it open. Won't hurt a thing. ![](/ubbthreads/images/graemlins/thumbs.gif) Best thing you could do is eliminate it (2BBL) with the manifold. What I mean is, take the 2BBL manifold off, and put a 4BBL on it. I did with my 360, loved it. Never looked back. ![](/ubbthreads/images/graemlins/drive.gif)
[Re: TimS]
#1496346
09/05/13 04:54 PM
09/05/13 04:54 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
[image] [/image]
Got one on my 72 Barraucda 318 2bbl. Those BBD's are good little carbs. Ran for years with my vent tube open without issues. It'll stumble on takeoff if you plug it.
This one never stumbled !!
[Re: 62maxwgn]
#1496349
09/05/13 09:47 PM
09/05/13 09:47 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Vac advance is the one on the passenger side. Choke diaphragm is the small one on the back. Big on the bottom of course is the PCV.
Good carbs. I love BBD's. I better model would be one with a "tin top." I think '76 and newer. The ones that have a bent PCV fitting are for slants. (I buy those!)
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: TimS]
#1496351
09/06/13 10:26 AM
09/06/13 10:26 AM
62maxwgn
Blair County,PA
[image] [/image]
Not the same carb. Different venting.
You think nI didn't know that !! ![](/ubbthreads/images/graemlins/no.gif)
