Page 1 of 6 1 2 3 4 5 6
Transmission explosion video at Bristol Mopar show #1495901
09/03/13 11:19 PM
09/03/13 11:19 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
Racethis.com caught this transmission explosion at Bristol fri on video. Driver was injured, broken foot, 3rd degree burns to his face and hands and a piece of shapnal to the eye, but will be back.
Check out video here http://www.youtube.com/watch?v=aFc-z5q3i...O4j6YHH5eXBeKNw
If I can get still photos of the damage, I will try to post them later.
Brian
Re: Transmission explosion video at Bristol Mopar show [Re: '72CudaRacer] #1495902
09/03/13 11:29 PM
09/03/13 11:29 PM
Mooresburg, Tn
Mooresburg, Tn
Floor board
Re: Transmission explosion video at Bristol Mopar show [Re: '72CudaRacer] #1495903
09/03/13 11:30 PM
09/03/13 11:30 PM
Mooresburg, Tn
Mooresburg, Tn
Still photo.
Re: Transmission explosion video at Bristol Mopar show [Re: '72CudaRacer] #1495904
09/03/13 11:36 PM
09/03/13 11:36 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Man, lot's of flame. Glad it wasn't anymore serious. Don't see any kind of shield. That's a good size hole.
Re: Transmission explosion video at Bristol Mopar show [Re: rickraw] #1495905
09/04/13 12:02 AM
09/04/13 12:02 AM
Mooresburg, Tn
Mooresburg, Tn
This is pretty graphic. I run a trans shield, but this video is making me rethink a open face helmet and no gloves. Just before the car comes to a stop, you can see him trying to get his head out of the fire.
Brian
Re: Transmission explosion video at Bristol Mopar show [Re: '72CudaRacer] #1495906
09/04/13 02:04 AM
09/04/13 02:04 AM
Finland, Europe
Ck[FIN] Offline
Ck[FIN]  Offline
Finland, Europe
Brian
Seems like no shield was used?
Here in our rules if you have 10.99s or faster you must have shield. Also gloves are a must if you drive at any speeds. Also if your speed is 9.99s or faster you cannot use open face helmet.
Glad the driver is ok.
-1965 Valiant 9.03s 358cu.in R5P7-
Re: Transmission explosion video at Bristol Mopar show [Re: Ck[FIN]] #1495907
09/04/13 02:12 AM
09/04/13 02:12 AM
Arizona
Chris'sBarracuda Offline
Arizona
Gotta love them Torqueflights..
Chris..
Re: Transmission explosion video at Bristol Mopar show [Re: Ck[FIN]] #1495908
09/04/13 02:16 AM
09/04/13 02:16 AM
Florida STAYcation
IcorkSOAK Offline
Financed his waterbed
IcorkSOAK  Offline
Florida STAYcation
Scarey stuff...plus he wrecked his car. Alum or billet steel drum would have prevented that
Re: Transmission explosion video at Bristol Mopar show [Re: IcorkSOAK] #1495909
09/04/13 04:50 AM
09/04/13 04:50 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Low band apply valve body is good insurance also.
I did some work on a Dakota for a guy. He refused to let me complete the cage says he does not want something that looks like a race vehicle. Refuses to replace the drum and is running an outdated valve body. I'm sure it will be my fault if VMP does not let him run at the Mopar show.
Re: Transmission explosion video at Bristol Mopar show [Re: Leon441] #1495910
09/04/13 08:17 AM
09/04/13 08:17 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
This is the reason I welded a piece of steel plate on the floor board when I did my cage!
Re: Transmission explosion video at Bristol Mopar show [Re: TheOtherDodge] #1495911
09/04/13 09:45 AM
09/04/13 09:45 AM
PA
moparacer Offline
moparacer  Offline
PA
OMG...
Watching that makes me want to go ahead with the 904 swap I was planning over the winter.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 5.44-126
414 cid SB Dragster 7.65-174
Re: Transmission explosion video at Bristol Mopar show [Re: TheOtherDodge] #1495912
09/04/13 09:48 AM
09/04/13 09:48 AM
Az
Crizila Offline
Crizila  Offline
Az
Good idea, and I think I might look in to that when my shat box is apart again. I do run a blanket style shield, but it is a hassle to work with / install. I also run a low band apply and a steel front drum.
Fastest 300
Re: Transmission explosion video at Bristol Mopar show [Re: '72CudaRacer] #1495913
09/04/13 09:48 AM
09/04/13 09:48 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Wow that is a bad one, would make me nervous to run a torqueflite.
Where's that so called dragster racer who says it's fine to race with hardly any safety gear on because NHRA sucks and it's hot out. Whinny little man, I never heard such whinning.
Re: Transmission explosion video at Bristol Mopar show [Re: Challenger 1] #1495914
09/04/13 10:27 AM
09/04/13 10:27 AM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
Whoa! That has to sting!
"Watching that makes me want to go ahead with the 904 swap I was planning over the winter"
Is the 904 not the same as the 727 when it comes to explosions like this?
Re: Transmission explosion video at Bristol Mopar show [Re: gtsdude] #1495915
09/04/13 10:31 AM
09/04/13 10:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
No they are not... the 904 has a smaller drum so the
RPM has to be much higher to get the centrifugal
force for it to explode ... when the sprag rolls over
(breaks) it spins the drum 2.2 times the engine rpm
Re: Transmission explosion video at Bristol Mopar show [Re: gtsdude] #1495916
09/04/13 10:36 AM
09/04/13 10:36 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I sure LOVE my powerglide sitting behind my big and small block engines. Then again its usually the driver fault 98 out of 100 times for not knowing when, how or WHY your transmission needs checked out.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: Transmission explosion video at Bristol Mopar show [Re: pittsburghracer] #1495917
09/04/13 10:45 AM
09/04/13 10:45 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Is that Al Bundy's car?
"A Dodge Duster suffers from an extreme transmission failure"
Re: Transmission explosion video at Bristol Mopar show [Re: B5 Bee] #1495918
09/04/13 12:03 PM
09/04/13 12:03 PM
Kingsville, Md
grncpe Offline
grncpe  Offline
Kingsville, Md
had the same thing happen to me.my floor looked a lot worse. I ran a blanket,broken foot,torn ligaments in my ankle, on crutches for six months. I run turbo 4oo's now. I had open face helmet, snap ring for the clutch pack shot past my face. I hate to see this,just painfull! Hope he is ok. I had an ATI trans in mine,
Re: Transmission explosion video at Bristol Mopar show [Re: '72CudaRacer] #1495919
09/04/13 12:13 PM
09/04/13 12:13 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
Brian
I dont see a shield on the trans but Iam thinking this is the last video I will watch of 727 go up in flames. Iam done with the them.I do have to wear full helmet and gloves BUT i kind of like my feet and legs also.TH400 or glide going in my Mopars!
Re: Transmission explosion video at Bristol Mopar show [Re: poisondart2] #1495920
09/04/13 01:00 PM
09/04/13 01:00 PM
I've seen Turbo 400 do the same thing, KABOOM
