Starter motor??? #1495898
09/03/13 11:18 PM
09/03/13 11:18 PM
Newfoundland Canada
Mopar1 Offline OP
Mopar1  Offline OP
Newfoundland Canada
A friend of mine has a '61 Chrysler LeBaron with a 413 and the cast iron torque flight trans..The starter is on the fritz, will the later reduction starter fit and work with the older set-up??
Re: Starter motor??? [Re: Mopar1] #1495899
09/04/13 09:37 AM
09/04/13 09:37 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yes! get a rebuilt from a 92 or so Dakota.
You may have to pop the plastic and take the extension off the top of the starter but otherwise.
Re: Starter motor??? [Re: Mopar1] #1495900
09/04/13 12:21 PM
09/04/13 12:21 PM
Great White North
W
Wheeler Offline
Wheeler  Offline
W
Great White North
A reduction gear starter will not work on your friend's 1961 Chrysler (assuming it's the original engine and transmission in the car).
Pre-1962 Chrysler products use a direct-drive style starter. I would recommend getting the starter rebuilt by a automotive electrical repair shop.
Good luck!
