Re: yes?no?maybe? 1966 B-body 15x8,4 5/8s BS what size tire
[Re: floridian]
#1495620
09/05/13 12:50 PM
09/05/13 12:50 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
I had a 15X7" OEM steel wheel with 4.25" BS on my 67 Belvedere. Tire size was 275-60-15. I could barely squeeze it into the wheel well. I had to disconnect the shocks so the housing could drop a bit more just to get in in there. They were too much of a hassle so I took them off. I don't recall how much room there was between the tire and spring. The 4.625" BS on your wheel may help a 275-60-15 fit better. When I get the car back on the road, it will have a 255-70-15 on the same 15X7" wheel rear, a 225-70-15 on a Torque Thrust 15X6" front. A 255-60-15 tire would also fit nice on the rear but I need a tall tire to make up for the 4.88 gear (till I get it changed to 4.10). ![](http://pic50.picturetrail.com/VOL487/1398298/2663400/34252299.jpg)
[Re: B5 Bee]
#1495621
09/05/13 04:55 PM
09/05/13 04:55 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
My 65 coronet has 15x8 with 4.5/8 and I have 295/50/15 on it with SS springs and I could go bigger. the lip of the fender is 2 inches above the wheel. No mods to the spring perches. ![](/ubbthreads/images/graemlins/beer.gif)
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
