Re: BB 11" manual drum brakes [Re: RSNOMO] #1495311
09/12/13 02:46 PM
09/12/13 02:46 PM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
at least one rear gives a solid fill on the pump - I don't recall on the other. The front simply gives a trickle.
Re: BB 11" manual drum brakes [Re: MOPAULY] #1495312
09/12/13 03:01 PM
09/12/13 03:01 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Top off the master, get somebody out there with you...
Pump 'em up and crack a front bleeder...
If you've got good flow to the wheel cylinder, but little out of the bleeder, that really only leaves the wheel cylinder...
Are the bleeders clear???
Re: BB 11" manual drum brakes [Re: RSNOMO] #1495313
09/13/13 12:04 PM
09/13/13 12:04 PM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
I have a power bleeder, no need for 2 people. Bleeders pull fluid just fine when tested, issue somehow must be with the wheel cylinders.
Re: BB 11" manual drum brakes [Re: MOPAULY] #1495314
09/13/13 12:25 PM
09/13/13 12:25 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Hope you're positive of the adjustment. The shoes need to ride pretty close to drums or pedal will be low.
Re: BB 11" manual drum brakes [Re: MOPAULY] #1495315
09/14/13 04:00 AM
09/14/13 04:00 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
When I rebuilt the 11" manual drum brakes on my '69 Coronet, I got the springs and self adjuster kit for the '70 model to get rid of the manual adjusters.
I hope you bench bleed the master cylinder before installing it.
Re: BB 11" manual drum brakes [Re: 451Mopar] #1495316
09/15/13 03:00 PM
09/15/13 03:00 PM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
Adjustment seems good and it was bench bled. I've manually bled it a few times since the issue and its better. Not perfect, but better and driveable.
