Re: Meth injection..who runs it? [Re: Mr.Yuck] #1494829
09/02/13 08:33 PM
09/02/13 08:33 PM
1974Cuda360 Offline
1974Cuda360  Offline
Both meth and an intercooler reduce air intake temperatures on force inducted engines, but only meth provides the extra octane increase.
Re: Meth injection..who runs it? [Re: mopardude318] #1494830
09/02/13 08:51 PM
09/02/13 08:51 PM
Az
Crizila Offline
Crizila  Offline
Az
Check out snow performance.
That's what I run with my blower motor. IMO, one of the best systems out there. Lots of options to choose from and very tunable for almost any application.
kind of off topic, but are you using a 6 or 10 groove pulley system on your supercharger?
8 groove.
Fastest 300
Re: Meth injection..who runs it? [Re: Hot 340] #1494831
09/02/13 09:15 PM
09/02/13 09:15 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
to answer 1 of your questions,up to 20% of the fuel can be water meth and you figure that by how much hp you make.
Re: Meth injection..who runs it? [Re: Hot 340] #1494832
09/03/13 01:02 AM
09/03/13 01:02 AM
Az
Crizila Offline
Crizila  Offline
Az
Looking for info on meth injection. Where is methanol acquired? Cost effective? How much is used per gallon of gasoline roughly? How about suggested kits? We are going to be putting a new bullet in my brother's car soon and wondering about this option for a high comprsssion street shortblock we have laying here for it. Sorry for all the questions..I know nothing about it.
Couple things you need to understand about these systems. The main purpose to run a water/alcohol system is to keep your motor out of detonation, which will allow you to run high C/R ( or boost if your blown) and the necessary timing advance to make good power. The systems, by themselves, do not make power - IMO, despite some ridiculous claims - again IMO. Most run winter blend windshield solvent, which is usually around 30% alcohol. The rest is colored water. The "Snow" system in the pic I posted consists of ( from the drivers seat ) the reservoir bottle with a low level light to the right of the rad. The pump is located under the right side hood hinge. Control box is on the firewall to the left of the pump. It contains 2 adjustable pots. One controls when the pump turns on ( mine is set for 5 psi). The other pot controls at what psi the pump runs at full capacity. As the boost goes up, the pump speeds up to supply more fluid to the spray nozzle. To the left of the control box on the firewall is an inline solenoid to prevent the fluid from siphoning from the reservoir when the system is off. The red line exiting the solenoid goes to a 1" jet/ nozzle plate under the carb. System comes with 3 different size spray nozzles for additional tuning. You want to run the least amount of fluid necessary to keep your motor out of detonation. Hope this helps.
Fastest 300
Re: Meth injection..who runs it? [Re: Crizila] #1494833
09/03/13 09:02 PM
09/03/13 09:02 PM
Pa
Hot 340 Online content OP
Hot 340  Online Content OP
Pa
Sounds like a legit setup..wonder why it isnt more popular? Is it a new thing?
Re: Meth injection..who runs it? [Re: Hot 340] #1494834
09/04/13 12:17 AM
09/04/13 12:17 AM
Az
Crizila Offline
Crizila  Offline
Az
Not new. Also not cheap, but nether is building a blower motor - or blowing one up .
Fastest 300
Re: Meth injection..who runs it? [Re: Crizila] #1494835
09/04/13 08:12 AM
09/04/13 08:12 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
The Snow kit has gone up in price. I think when I got mine 3 years ago it was only $250, now they are $300. Still if you race a lot, and usually use race gas, it will more than pay for itself in one year. And if you keep one piston from burning up, even better.
Re: Meth injection..who runs it? [Re: Hot 340] #1494836
09/04/13 01:02 PM
09/04/13 01:02 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Because they are really for diesels.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Meth injection..who runs it? [Re: 1974Cuda360] #1494837
09/04/13 01:13 PM
09/04/13 01:13 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
FYI
Re: Meth injection..who runs it? [Re: Slingshot383] #1494838
09/04/13 11:12 PM
09/04/13 11:12 PM
Amherst,NY
challengermike Offline
Amherst,NY
Meth injection isn't only for diesels, The turbo buick guys have been running it forever. It just became popular lately because so many people are putting turbo's on everything.
You don't really use that much meth. I would go threw about 1 gallon of denatured alky in 6 months, That was on a 86 t type running 11.70s that was raced and street driven a lot. It was also an older SCM non progressive kit. The only problem I have with running it was 1 time on a pass the pump stopped working which caused the head gaskets to blow. So after that I started mixing in some race gas just incase.
Re: Meth injection..who runs it? [Re: challengermike] #1494839
09/05/13 10:53 AM
09/05/13 10:53 AM
Bolig Offline
Bolig  Offline
Guys, I just spent a couple days with Matt Snow at his shop. He installed a unit on a fairly mild 440 6 BBL, and I must say, it did make a difference. I can't give out too much information yet, as we're working on an article about it for the February issue. Let's just say, it allowed us to increase timing (42-degree total), and horsepower. Keep in mind, this could be considered a fairly mild 440. The results will probably be exponential depending on the engine combination.
Re: Meth injection..who runs it? [Re: Bolig] #1494840
09/05/13 10:57 AM
09/05/13 10:57 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I noticed it as well. I used my butt duno, but I can say I have no issues at 11.2:1 37* full advance in early (2000). Haven't done it at the track on a full pass but I have done a few short bursts w/ and w/o and you can feel the extra umph.
Bolig how did you plum yours? This is how I ran mine.
http://www.youtube.com/watch?v=JYw2q7igDGs
Re: Meth injection..who runs it? [Re: Mr.Yuck] #1494841
09/06/13 01:44 PM
09/06/13 01:44 PM
Bolig Offline
Bolig  Offline
Without getting to detailed,the tank is mounted to the radiator support on the passenger's side, and the pump is underneath the tank. From there, the two nozzles are mounted under the Six Pack air cleaner base, and they spray into the air cleaner area when needed. The vacuum then sucks the meth/water mix into the carburetors.
