Cam degree question
#1493996
09/01/13 04:46 PM
09/01/13 04:46 PM
Posts: 1,221 Jarrettsville, MD
tywebb2
super gas
super gas
Jarrettsville, MD
I am in the middle of a new cam install and have a question about degreeing it. It is a Lunati cam that has a LSA of 110 and an installed centerline of 106. They told me it has 4deg of advance built in. Well I installed it lining up the dots earlier today and it degreed in at 110 on the #1 intake which to me would mean I need to advance it 4deg. Is my thinking correct? I want it to come in at 106 when degreeing it...right.
'72 440 Cuda 11.673 @ 115.91 w/1.663 60'
Re: Cam degree question
[Re: tywebb2]
#1493997
09/01/13 04:56 PM
09/01/13 04:56 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You are correct.. forget about the 4* built into it.. install it at 106(or maybe 104) depending on the total set up. but the lower the install gives you more LOW END torque) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Crizila]
#1494000
09/01/13 05:19 PM
09/01/13 05:19 PM
tywebb2
super gas
super gas
Jarrettsville, MD
I thought if I retarded it 4* that would put me at 114*....right? Don't I want to advance it 4* to get to 106*?
[Re: tywebb2]
#1494001
09/01/13 05:22 PM
09/01/13 05:22 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Yep you want to advance it and not retard it. As I remember your 60 ft.s were a little slow for you Et so you might even want it in @ 104 ICL
[Re: Crizila]
#1494002
09/01/13 05:24 PM
09/01/13 05:24 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
You are right as you are doing it by max lift on the intake lobe. You want max intake lobe lift centerline at 106 after TDC. Advance it 4 degree. My cam is also a 110 LSA and I have it on 106 also. Ron
