727 problem? #1493725
08/31/13 11:32 PM
08/31/13 11:32 PM
Stratford,Ct
7sec.cuda Offline OP
Stratford,Ct
I started my other race car after a two year hibernation and had it running about 10 minutes just started to get some temp into it and decided to put it in gear.tried reverse and nothing so I tried first and nothing and that's when I realized I drained the fluid when I parked it. So I shut it off and add 6 qts of fluid seems to shift fine . My question is did I do any damage runnin without fluid? Thx it's a 727 with only about 10 passes on it
Re: 727 problem? [Re: 7sec.cuda] #1493726
08/31/13 11:36 PM
08/31/13 11:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Naa... its not like it was slipping... you didnt have
any fluid to cause a slip... the only thing might have
been the pump but it unlikely
Re: 727 problem? [Re: MR_P_BODY] #1493727
09/01/13 12:00 PM
09/01/13 12:00 PM
Stratford,Ct
Stratford,Ct
Re: 727 problem? [Re: MR_P_BODY] #1493728
09/01/13 01:33 PM
09/01/13 01:33 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
X2,
Probably enough oil in the pump to keep it lubed as long as it wasn't running forever. Most likely couldn't make any pressure so the clutch packs may be ok.
Would have been in more trouble if there was some fluid in the pan sufficient enough to develop some pressure and drive the car only to suck it dry under accel/decel and slip the clutches under power.
AG
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: 727 problem? [Re: turbobitt] #1493729
09/01/13 10:55 PM
09/01/13 10:55 PM
Stratford,Ct
Stratford,Ct
Hopefully I didn't hurt it thanks
