turn signal flasher: E-body
#1493602
08/31/13 05:44 PM
08/31/13 05:44 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang... Where, typically, is the turn signal flasher located on a 71 Challenger? I'm trying to trouble shoot and for the life of me, I can't find the flasher and/or the red/black dual wire connection.......
Is this it? Near the bulkhead connector? This is a picture from a 'Cuda... Not sure if Challengers and 'Cudas are the same...... and if years matter.......
Cheers, Troy
Re: turn signal flasher: E-body
[Re: hemi68charger]
#1493603
08/31/13 06:23 PM
08/31/13 06:23 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Mine lives in a special clip up under the dash just beneath the ashtray. Not sure if that is the correct original location though.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: Michael Ecks]
#1493604
08/31/13 06:35 PM
08/31/13 06:35 PM
hemi68charger
Houston, Tx
Cool, thanks... I'll poke my face up there too with a mirror.....
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: Michael Ecks]
#1493606
08/31/13 09:03 PM
08/31/13 09:03 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
Same in the 1971-1974 B-body. You should be able to remove the ashtray receiver with 3 screws. Once out, there is a clip that holds the flasher you want but it may have fallen out. Either way, you should be able to reach in there and access what you need.
The flasher you have pictured by the bulkhead is the emergency flasher.
