Rail Number #1492650
08/29/13 07:39 PM
08/29/13 07:39 PM
Unfortunately back in New York
N
Nukechargerboy Offline OP
N
I found a number on the rail between the engine and transmission. I have no idea what it means :8B239224 Help please .
Re: Rail Number [Re: Nukechargerboy] #1492651
08/29/13 07:55 PM
08/29/13 07:55 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
1968 Date Code
B Assembly Plant
239224 Last six of the VIN
Admiration For Multiple Carburetor Vehicles...
Re: Rail Number [Re: Stewpar] #1492652
08/29/13 08:00 PM
08/29/13 08:00 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I am assuming a Dart or Barracuda? I assume you are talking about the bellhousing mounting rail on the engine, they started putting the VIN on them early in the 68 model year, hopefully it matches the VIN on your car!
JB Rhinehart, Realist
A-Body's RULE!
Re: Rail Number [Re: Rhinodart] #1492653
08/29/13 08:11 PM
08/29/13 08:11 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Pretty sure B code was Hamtramck, Michigan?
Re: Rail Number [Re: Stewpar] #1492654
08/29/13 08:12 PM
08/29/13 08:12 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Yep, that is why I said what I did.
A-Body's RULE!
Re: Rail Number [Re: Rhinodart] #1492655
08/29/13 09:38 PM
08/29/13 09:38 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
I am not the A body guru like you Jim! B/E, I can hold me own!
Re: Rail Number [Re: Stewpar] #1492656
08/29/13 10:41 PM
08/29/13 10:41 PM
N
N
Well this is the engine that was in my 68 charger, a st louis car. If it can be deciphered to be someones engine, I'let them have it. I'm making my 383 2 bbl plain jane into a R/T tribute.
The numbers are no where near my vin.
Re: Rail Number [Re: Nukechargerboy] #1492657
08/29/13 10:48 PM
08/29/13 10:48 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
That is interesting! If it were an A-Body 383 then it will have holes drilled into the block above the oil pump boss and the rear driver's side boss for the top motor mount hole will be shaved off, so a regular B-Body mount top hole will have nowhere to bolt on!
A-Body's RULE!
Re: Rail Number [Re: Rhinodart] #1492658
08/29/13 11:25 PM
08/29/13 11:25 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
What in the last 8 makes you assume A body?
Just trying to learn, thanks.
Careful, your character's showing!
Re: Rail Number [Re: mopar346] #1492659
08/30/13 10:31 AM
08/30/13 10:31 AM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Each assembly plant only produced certain models..........
Re: Rail Number [Re: Rhinodart] #1492660
08/30/13 10:32 AM
08/30/13 10:32 AM
N
N
Both mounting bosses are present. I'll hafta look harder for more numbers, hopefully I can find some more. I can tell you it was cast on day shift on 12/7/67.
Re: Rail Number [Re: Nukechargerboy] #1492661
08/30/13 11:41 AM
08/30/13 11:41 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Engine & automatic transmission from a 383 4bbl Charger: XP29H8B239224 - "scheduled" to be built on Friday December 15, 1967. I don't know the car or if it still exists.
Can you get the info off of the driver's side transmission pan rail.
Re: Rail Number [Re: 6bblgt] #1492662
08/30/13 01:11 PM
08/30/13 01:11 PM
N
N
PK2801543K 2442 9524. These are the numbers. If you need casting numbers and such, let me know. Great information guys. The VIN for this car is XP29G8G221xxx.
Re: Rail Number [Re: Nukechargerboy] #1492663
08/30/13 01:25 PM
08/30/13 01:25 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I misunderstood - ONLY the OP's subject engine is stamped at the parting line - not both.
Transmission appears to be the original 727 to your car & won't have a partial VIN# stamping.
transmission PK2801543K (383 2bbl) 2442 (Thursday 4/4/68) 9524 (unit number)
Your Charger was built mid-April '68.
Re: Rail Number [Re: 6bblgt] #1492664
08/30/13 01:55 PM
08/30/13 01:55 PM
N
N
Thanks so much Dan. At least now I know the trans is legit. Hopefully someone out there has this car, I'll trade em engines. Anybody in Arkansas know the block? That's where my car came from.
Re: Rail Number [Re: 6bblgt] #1492665
08/30/13 02:30 PM
08/30/13 02:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I misunderstood - ONLY the engine is stamped at the parting line - not both.
Re: Rail Number [Re: John_Kunkel] #1492666
08/30/13 02:49 PM
08/30/13 02:49 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Thanks, John - the OP's example is a stamped engine (383 4bbl) not original to his car & an unstamped transmission (727 for a 383 2bbl) original to his car.
I went back & read the entire post - is the OP's partial VIN stamped engine a 383?
What's stamped on the block below the distributor?
Re: Rail Number [Re: 6bblgt] #1492667
08/30/13 03:02 PM
08/30/13 03:02 PM
N
N
D383 12 212. Thanks guys, these are the numbers I found on the pad. This engine has been orange since I bought this car in 96. I can't find any turquoise paint, I guess it must've been stripped at some point.
Re: Rail Number [Re: Nukechargerboy] #1492668
08/30/13 03:38 PM
08/30/13 03:38 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
D383 12 212
D = 1968 model year
383 = 383 cu.in.
12 = December
21 = 21st of month (Thursday 12/21/67)
2 = second shift
So, this 12/15 "scheduled" (C15-SPD) Charger was 6+ days late.*
* unless the numbers on the stamped pad got messed up & it's actually 12/12/67 and second shift
D = 1968 model year
383 = 383 cu.in.
12 = December
2 = second shift
12 = 12th of month (Tuesday 12/12/67)
Re: Rail Number [Re: 6bblgt] #1492669
08/30/13 04:17 PM
08/30/13 04:17 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Is there anything stamped on the bottom, below the starter mounting?
