Re: Advantages of T56 over Passion 5 speed?
[Re: 72Swinger]
#1492564
08/30/13 12:43 AM
08/30/13 12:43 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
T-bar crossmember is 2x1/2x1/4" C-channel that is plated underneath the bends.
Mopar to the bone!!!
[Re: 72Swinger]
#1492565
08/30/13 12:44 AM
08/30/13 12:44 AM
72Swinger
Nebraska
Rear of it
[Re: 72Swinger]
#1492568
08/30/13 12:51 AM
08/30/13 12:51 AM
72Swinger
Nebraska
18 gauge sheet for tunnel.
[Re: Jerry]
#1492571
08/30/13 10:29 AM
08/30/13 10:29 AM
Posts: 22,697 Bitopia
jcc
Bitopia
Has the richmond 5 spd lost all favor in this discussion?
[Re: jcc]
#1492573
08/30/13 03:57 PM
08/30/13 03:57 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
isn't the richmond a 1:1 5th gear, making it an ideal "race only" transmission? the question here is about the Passion OD trans vs the T56, an OD trans.
anyway, I love the T56. I have one in my Dakota and don't have any complaints. Now, for the 3rd generation Dakota, it truely is a "bolt in" transmission, no sheetmetal modification required.
that said, I spent $1500 in the transmission off Ebay (used Viper spec T56) the quicktime bell was about $500, and then I got a custom flywheel made that had the tone ring for the factory EFI, cost me about $500. (non EFI motors can use a much cheaper flywheel option) and I have about $250 in my clutch.
the hydraulics are a hybrid of the SRT-10 truck hydrualic bearing (yes, slightly different than the viper part) and the stock Dakota master cylinder.
it was a pretty simple swap that if I had a factory 5-spd truck and the parts, I could knock it out in a day. If I had to start with an auto truck that needed a hole cut, and pedals added, then I would venture to say that it might take me a day and a half to 2 days.
**Photobucket sucks**
[Re: 70Cuda383]
#1492574
08/30/13 04:15 PM
08/30/13 04:15 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
No, not necessarily. It simply allows you to reduce rear end ratios and use "economy" gear sets like 2:94, 3:08, and 3:23, which a lot of guys have kicking around as throw aways.
[Re: AlexP]
#1492578
09/09/13 07:16 PM
09/09/13 07:16 PM
Posts: 126 mass
kotacars
mass
The biggest advantage for the T56 is the fact that it exists.
price I got a 2005 viper t56 6spd with 3,000 miles on it I know because I took it out of the car for 1,700 dollars then I put it behind my 600 hp small block now I have miles of smiles lol
[Re: PHJ426]
#1492579
09/09/13 08:48 PM
09/09/13 08:48 PM
Posts: 2,836 Detroit boy in Saugerties, NY
BrianShaughnessy
I put a T56 in my old 89 Firebird after taking out a T5... so much happier. It was from a 95 TA / 2.66 1st, .5 6th. 3.70 gears in the car... it's awesome. If anything tho a .62 6th gear would be better. .5 is just too much.
The TKO600 made me so much happier than rowing the 833 in the Charger... the only perceivable problem is the big drop from 4th to 5th with the .64 5th and 3.73 gears. Somewhere between 45 to 50 mph I start thinking about upshifting but I really need to wait till 55ish.
If you got the guts I'd do the T56... I sorta wish I did myself.
If you got a friend with a T56 equipped car I'd recommend taking one for a ride just to try it out.
Black Betty: '69 Charger RT: 440 6 pack, TKO600 5 speed, 3.73 Dana. Sinnamon: '69 Charger RT: 440, 727, 4.30 8.75. High School Sweetheart. El Grande: '98 Grand Cherokee 5.9 Limited.
[Re: BrianShaughnessy]
#1492580
09/09/13 09:21 PM
09/09/13 09:21 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
None that I can see, that's comparing apples to oranges IMO.
The Passon is a bolt in 5 speed with ZERO hacking required to install it (The Passon is all alone in this niche, there is no competition) plus the Passon uses the stock bell housing, clutch, drive shaft, shifter location, etc. For an original car I don't see that there are any other good choices.
[Re: PHJ426]
#1492582
09/09/13 10:49 PM
09/09/13 10:49 PM
Posts: 2,432 NorCal
RylisPro
NorCal
My question should have probably been more specific like is it really necessary to have 6 speeds instead of 5 in a car that gets driven on the street to get to the track or high speed driving event .......not for a concourse show car.
No, it is not NEEDED to have a 6 speed but I had one installed because I have always WANTED one in my car. My other car is a 6 speed and I would not have been happy with any less gears. I saved up my money for a long time and went ahead with the install before I got to spend it on anything else. Believe me I was on the fence about the install but I figured you only live once and said screw it what do I got to lose?!
I did notice that my gas mileage went up though!
[Re: PHJ426]
#1492583
09/09/13 10:53 PM
09/09/13 10:53 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
If a car has a 5 speed installed does that make it "not original"?
I do understand your point on the cutting the floor and trans/torsion bar mount cross member.
You just answered your own question.
There has to be a point where an all original car is 100% original things like Detroit Air in the spare and so on.
Not sure what your question is on that one?
In my experience a 6 speed won't offer much real world advantage over 5 speed for a driver or occasional track car.
What I like about the Passon 5 speed is simply this; If someone has a stock car with a body that hasn't been modified in any way and who wants to install a transmission which will allow the car to be more fun to drive he can do so with no worries about originality, and that's because it's a simple bolt in to swap back the stock original without worrying about body work on the floors and tunnel. The rarer and more desirable the car, the more this matters to some.
