pulling the oil pan on the 4x4 rc w/360 #1492407
08/29/13 01:06 PM
08/29/13 01:06 PM
Toledo, Ohio
70FJ5383 Offline OP
70FJ5383  Offline OP
Toledo, Ohio
So can the pan be pulled as she sets or do i have to raise the motor up some. It looks like there might be enough room. I'd like to pull it and maybe replace the oil pump. Slight bearing noise at first start-up but goes away in 1 or 2 seconds. Oil pressure comes up kind of slow but always climbs to 40 lbs at idle. No bearing or lifter noise after she's running. I'll probably check the bearings too. Has anybody done this?
Re: pulling the oil pan on the 4x4 rc w/360 [Re: 70FJ5383] #1492408
08/29/13 01:10 PM
08/29/13 01:10 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
You can do it and it's a great idea, you don't have to loosen the engine mounts.
Sheldon
Re: pulling the oil pan on the 4x4 rc w/360 [Re: 70FJ5383] #1492409
08/29/13 02:00 PM
08/29/13 02:00 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Yes, above is correct. The pan drops right out. I even swapped a crank years ago in my driveway without removing eng on a 79 w150. At 40 pounds at hot idle I wouldn't worry about that pump though. The mild pounding for 2 seconds means there is a tad bit of race clearance.
Re: pulling the oil pan on the 4x4 rc w/360 [Re: buildanother] #1492410
08/29/13 04:02 PM
08/29/13 04:02 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
A new pump wont fix bad bearings.
I am truckless..
Re: pulling the oil pan on the 4x4 rc w/360 [Re: 340SHORTY] #1492411
08/29/13 08:47 PM
08/29/13 08:47 PM
Toledo, Ohio
70FJ5383 Offline OP
70FJ5383  Offline OP
Toledo, Ohio
Yeah that makes sense, if i have good pressure it probably is a worn bearing making noise. Oil pump is doing its job. Guess I'll check the rod bearings see what they look like. Thing only has 69k miles but I don't know any history. Thanks guys.
Re: pulling the oil pan on the 4x4 rc w/360 [Re: 70FJ5383] #1492412
08/29/13 09:07 PM
08/29/13 09:07 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I suggest plastigauging the mains and rods.
Re: pulling the oil pan on the 4x4 rc w/360 [Re: 76dodgeboy] #1492413
08/30/13 04:23 PM
08/30/13 04:23 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
I don't know what year your truck is, but I would plan on replacing the timing chain while you are there. Also, make sure the pan bottom has not been pushed up close to the bottom of the pickup tube, and the pickup screen is free of debris. Gene
Re: pulling the oil pan on the 4x4 rc w/360 [Re: poorboy] #1492414
08/30/13 05:22 PM
08/30/13 05:22 PM
E
earlymopar Offline
earlymopar  Offline
E
Anyone have an extra front sump pickup tube laying around? Please PM me.
Thank you, -EM
Re: pulling the oil pan on the 4x4 rc w/360 [Re: earlymopar] #1492415
08/30/13 06:03 PM
08/30/13 06:03 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Thank you, -EM
There's a wanted section for such requests
Re: pulling the oil pan on the 4x4 rc w/360 [Re: 76dodgeboy] #1492416
08/30/13 06:40 PM
08/30/13 06:40 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Thank you, -EM
but a front sump pickup wont work in a rear sump pan...
I am truckless..
