1968 + 1970 Charger Dash Question... #1492263
08/29/13 08:52 AM
08/29/13 08:52 AM
ontario, canada
cool_cuda Offline OP
ontario, canada
Hey guys! I have a few questions my friend has a 1968 Charger R/T hes working on. When he got the car it came with a 70 dash. my question is will it work? what do we have to change ( lower dash panel,ignition switch ect ect)I know he really needs an R/T 68 dash to be 100% correct but he just wants it to work/ driver.
2) Whats a 70 Dash really worth in the real world?
3) Anyone got a 68/69 dash they might want to swap or sell?
Thanks in advanced!
Re: 1968 + 1970 Charger Dash Question... [Re: cool_cuda] #1492264
08/29/13 09:11 AM
08/29/13 09:11 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
It'll pretty much work, but you will have no flasher/emergency switch. In the '68, it was in the instrument cluster under the dimmer switch. Not sure what it is worth, but it will definitely be worth more than a '68/69... I doubt you will find a situation where you can get a complete swap, but best of luck in trying. You definitely should be able to sell it and then come up with the funds to get yourself a '68/'69 Rallye/Charger dash. That '70 looks to be in pretty nice original condition to be honest. Also, was the VIN transferred from the original dash to this '70?
I would throw this picture in the for sale section or trade and see what happens...
Cheers,
Troy
Houston Mopar Connection Club
Re: 1968 + 1970 Charger Dash Question... [Re: hemi68charger] #1492265
08/29/13 09:28 AM
08/29/13 09:28 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Cheers,
what he said, I'd try and sell that complete and buy the correct dash. I think some of the harness is going to be different as well. In 70 the ingnition switch is in the column. I'm guessing that dash is from an S/E???
Coming soon!!!!
Re: 1968 + 1970 Charger Dash Question... [Re: Mr.Yuck] #1492266
08/29/13 09:47 AM
08/29/13 09:47 AM
Houston, Tx
Houston, Tx
Or some unfortunate R/T...... All Charger R/T's in '70 had woodgrain dashes...
The only thing I might question is the light switch. The '70 has a electrical headlamp motor, so the circuit for that is in the headlamp portion of the dash harness. The '70 Dash switch doesn't have the provision for the vacuum switch either ( unless it is from a Superbird )...
The gauge connection on the printed circuit board is the same. Also, is the wiper switch in the '70 dash a 3-speed or 2-speed switch? Is the wiper motor in the car a 2speed or 3speed? Washer switch will be the same along with the dimmer switch. The 2 radio plugs ( speaker & power/light ) should be the same........ The heater and/or a/c switch panel will probably be different too...... If it is non-a/c, should be a problem...
Troy
Re: 1968 + 1970 Charger Dash Question... [Re: hemi68charger] #1492267
08/29/13 09:52 AM
08/29/13 09:52 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yeah that too.. maybe the VIN is still there and he can make a few more $$$$ JUST KIDDING
Re: 1968 + 1970 Charger Dash Question... [Re: Mr.Yuck] #1492268
08/29/13 01:32 PM
08/29/13 01:32 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Each year dash frame '68 - '69 - '70 is different, ignition switch mounting is the biggest difference '68 vs. '69.
'68 dash is Charger, Super Bee, & Coronet R/T w/gauges ONLY.
'70 wood grain dash shown is Charger R/T and/or SE, Super Bee, Coronet R/T w/gauges, & GTX ONLY (dash frame and gauges also used in Road Runner/Charger - no wood grain panels).
Re: 1968 + 1970 Charger Dash Question... [Re: 6bblgt] #1492269
08/29/13 05:30 PM
08/29/13 05:30 PM
ontario, canada
ontario, canada
Thanks guys for all the answers! I just really wanted a few opinions to show him I wasn't crazy for wanting to find a whole new dash. The Vin number is still on the dash from the 70 charger. You'll probably see it on here soon for sale!
Re: 1968 + 1970 Charger Dash Question... [Re: cool_cuda] #1492270
08/29/13 07:15 PM
08/29/13 07:15 PM
Loma Linda, MO
7812845 Offline
7812845  Offline
Loma Linda, MO
How much different is a dash frame from a 68 to a 69? I had a rallye frame from a 69 super bee until the Joplin tornado made it unusable and I need to find a replacement. Does it have to be a 69 for everything to work correctly?
2020 RAM Longhorn 4x4
2022 Jeep Grand Cherokee Overland
