Re: Lifting 92 W150
[Re: Hotlumpy]
#1492128
08/28/13 09:22 PM
08/28/13 09:22 PM
Posts: 15,487 Florida
scratchnfotraction
IMHO, no. nothing else needed.
but that is about max lift with stock chassis/driveline componets when off road/flexing the chassis/driveline.
i ran the 2" add a leafs from skyjacker front and rear with all stock chassis/driveline in a 79 RC.
I would recomend checking the front and rear slip yokes in the driveshafts for any slop up down or twisting back and fro when in N no load on them.
they will wear a groove over time and when you lide it out 1-2 inches you can get a wobble or vibs at speed with them.
also can get clunking in gear or when pulling off from a stop.
Re: Lifting 92 W150, leveling
[Re: 76dodgeboy]
#1492137
08/29/13 08:45 PM
08/29/13 08:45 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
On my last RC I added a front leaf. I used a Dakota rear main leaf that I cut the ends off. That leaf had more arc and it raised the front by about 2 inches. I also used a set of M880 rear springs. Made a world of difference..
I am truckless..
[Re: Hotlumpy]
#1492138
08/29/13 10:04 PM
08/29/13 10:04 PM
scratchnfotraction
Anybody ever use just the front add a spring to level out? I'll make some measurements at home, but I think that will bring the front up just enough. Anyone have a pick of a leveled or 2" lift on a short box?
i think i have done it every way it can be done on my 79 RC.
I got another front set of springs,busted them apart and added all 3 to the 3 I had. got about 3" lift.
i used just a add a leaf and it raised up 2", then add a leaf to rear while removing the short overload leaf from the stock rear spring pack. a little softer ride without it and not worth the 1/2" extra lift it might give you.
got to be carefull when stacking the leafs up in the front, the thicker the spring pack the front diff will need the 2 stock studs removed and replaced with grade 8 bolts with 1 longer u-bolt on that side.
drive shaft will be at the tip of spline/yoke and can come apart if flexing the chassis sideways enuff..
so be ready to lengthen the front/rear shaft if you go up over 2-3 inches.
IMHO if you just want it level, use the add a leafs front and rear and drop the stock lower leaf out of the rear spring pack.
this is how it should have come from the factory in the first place.
might look into the steering box frame brace if you dont have one on it, that is a great upgrade to any truck 2x or 4x4.
by the time I got done with that 79 RC, I had went from a 2" to 4" to 6" lift then used 6" front spring with a set of 12" rear springs,this done away with the stack of blocks and add a leaf in the rear.(it did sit nose up just a tad.)
running 17/40/15 ground hawgs on 12" Bart rims 4.56 gears did a lot of scratching with it.
[Re: Grizzly]
#1492141
08/31/13 12:14 PM
08/31/13 12:14 PM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
The lift was advertised as 1.5" and the truck developed a driveline vibration from the minute the lift kit was put in.
That's exactly what will happen. The pinion needs to be tipped back up about 2 degrees. Most quality lifts will have the pinion angle engineered into the lift so there will not be a vibration. Replacement longer studs are a must also.
I ran a Skyjacker softride 6 inch on my 84 w-150 and all I had to do was a steering arm and minor grinding on the front cv for the increased angle. That truck rode and handled very nice.
