3.5L and I need help. Timing related
#149184
11/11/08 08:10 AM
11/11/08 08:10 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
My car broke the tensioner bolt on the tensioner for the timing belt. The car was rolling along at 60 MPH when this happend.
I have since replaced the oil pump (tensioner screws into the oil pump housing) the tensioner and the belt.
I bought the special tool 6442 from Miller and aligned the camshafts per the FSM. I reinstalled the crank sprocket at TDC. The crank sprocket is keyed so I am fairly certain I installed it correctly.
When I try to start the car, it gives me a weird sounding starter engagement, but the crank is turning the timing belt, it tries to start, makes a sad back fire noise deep in the engine and then turns off. It will not fire after this unsuccessful start. I have to reset the computer.
I need ideas!
1. When I bought and used the camshaft alignment tools I thought their purpose was to hold the cams at the correct position relative to TDC of the crank. I thought once I could get the alignment tool installed, the cams were in the correct position.
2. The crank sprocket is keyed, I thought installing that along the keyway properly lined it up with TDC.
The car is not throwing codes. It threw one, P0016 the first time I tried to start it. That does not make sense if all the above is true. Ideas?
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
Re: 3.5L and I need help. Timing related
[Re: 70Coronet500Vert]
#149185
11/11/08 12:17 PM
11/11/08 12:17 PM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
Is the purpose of the cam tools to index them or merely to hold them in place? I remember doing belts on older(late 90's) 3.5 and don't remember a problem with markings, or needing a special tool. I just did a 3.2 and the marks were clear also, it even had the "tdc" on the oil pump to line the notch up with. It may be that you ended up with bent valve or valves, surely would be a drag. From working at chev, I know the old twin cam 3.4 was so obnoxious that a cam holding tool was used on one head, then belt gets installed and crank gets turned one revolution, then the same tool is used to hold cams on remaining head...weird.
#149186
11/11/08 07:10 PM
11/11/08 07:10 PM
70Coronet500Vert
St Charles MO
Bump for night crew.
On these new computer controlled engines, if I have bad compression, will it keep the car from firing?
#149188
11/12/08 12:16 AM
11/12/08 12:16 AM
Posts: 1,278 Mission BC
10sec440
Mission BC
Rick is right, but to answer your questions directly,1) yes the tools are to get the cams in the right spot. You only need to use them if you loosen the cam pulley bolt though.
2)"The crank sprocket is keyed, I thought installing that along the keyway properly lined it up with TDC." I'm not really sure what you are asking here. Yes the crank sprocket is keyed but after you install the sprocket you have to turn the crank to align the dot on the sprocket and the tab on the oil pump. If you did all that and it sounds funny on cranking you probably bent some valves. As Rick said its time to do a compression test. What year is it?
[Re: 10sec440]
#149189
11/12/08 08:42 AM
11/12/08 08:42 AM
70Coronet500Vert
St Charles MO
I will do a compression check. This is a 2002 3.5L Intrepid.
Yeah, I kinda threw it all together hoping nothing was bent. But, before I got home and could look at the car about 5 people tried to start it with the belt broke. So I think the question is, HOW MANY valves are bent.
I guess I will do that tonight. Of course, my stupid compression check probably won't thread into the head so I have to figure that out.
As far as the crank sprocket, I aligned it with the keyway, the rotated assembly to TDC. I did nto explain that well. So far as I can tell, I am timed exactly right.
I bought the cam alingment tools before I fully thought through and understood the timing marks on the cam sprockets and crank sprocket. I kept thinking I could be 180 out. But, even though the crank sprocket turns 2:1 to the cam sprocket, in the 1st alignment with TDC on the crank, the cams are pointing down, then the second alignment with TDC on the crank, the cams are between the dots. I am positive I am timed right.
I guess heads are next.
Of course, there is a hemi charger in FL I am bidding on that is going to go for under $14k.......
[Re: 10sec440]
#149191
11/13/08 12:51 PM
11/13/08 12:51 PM
70Coronet500Vert
St Charles MO
I'm just hunting for the compression test adapter for those spark plug threads. I will be doing this, this weekend. Bad compression, I will pull the heads.
In the meantime we have been renting a car. That's gonna stop. I am either buying a replacment, low mileage, newer car, or a stand-in, high mileage, older, this weekend.
The heads will take a couple weeks at the pace I work!
