V10 HP PARTS
#1491607
08/27/13 02:39 PM
08/27/13 02:39 PM
Posts: 109 OHIO
BUBBAZ572
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
ARE THERE ANY HP PARTS FOR THE V10 TRUCK ENGINE? HEADS INTAKE (UPPER AND LOWER) CAM SHAFT PISTONS & RODS IGNITION SYSTEM ANY BODY KNOW WHAT HAPPENED TO THE PERFORMANCE PARTS THAT WALKER EVENS USED IN OFF ROAD RACING IN THE 90'S? MY TRUCK CHASSIS DYNO AT 253HP AND 375 TORQUE BUBBAZ572@YAHOO.COM ![](/ubbthreads/images/graemlins/smilie_help.gif)
Re: V10 HP PARTS
[Re: BUBBAZ572]
#1491608
08/27/13 02:46 PM
08/27/13 02:46 PM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
They made a hotter Ignition box for the truck V10 you had to use Premium with it.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: V10 HP PARTS
[Re: 76dodgeboy]
#1491613
08/27/13 05:43 PM
08/27/13 05:43 PM
Savoy1964
Casco, MI
I got mine at a swap meet but it was a chrysler part.
Re: V10 HP PARTS
[Re: 76dodgeboy]
#1491614
08/27/13 07:20 PM
08/27/13 07:20 PM
Posts: 5,966 Greenville, PA
redraptor
Greenville, PA
Really! I was always under the impression the truck was a retubed viper motor
There is nothing shared between the two except for bore and stroke in the first years. ![](/ubbthreads/images/graemlins/Twocents.gif)
Re: V10 HP PARTS
[Re: BUBBAZ572]
#1491615
08/27/13 07:26 PM
08/27/13 07:26 PM
redraptor
Greenville, PA
ARE THERE ANY HP PARTS FOR THE V10 TRUCK ENGINE? HEADS INTAKE (UPPER AND LOWER) CAM SHAFT PISTONS & RODS IGNITION SYSTEM ANY BODY WHAT HAPPENED TO THE PERFORMANCE PARTS THAT WALKER EVENS USED IN OFF ROAD RACING IN THE 90'S MY TRUCK CHASSIS DYNO AT 253HP AND 375 TORQUE
BUBBAZ572@YAHOO.COM
There never really was a market to support that engine. It is what it is and you can buy headers redily and that's about it. You want to be different? Search a company to fab you up a rear turbo kit and customize the PCM. ![](/ubbthreads/images/graemlins/Twocents.gif)
Re: V10 HP PARTS
[Re: Golden-Arm]
#1491619
08/28/13 02:19 AM
08/28/13 02:19 AM
Posts: 4,258 Canada
WO23Coronet
Canada
There's nothing stopping you from porting the heads, getting a cam reground and putting headers on it, 253 HP isn't bad for a stock truck.
Re: V10 HP PARTS
[Re: 70Cuda383]
#1491621
08/28/13 08:19 PM
08/28/13 08:19 PM
redraptor
Greenville, PA
something isn't right there...
is it REALLY only 253?
a 5.9L V8 had 250 hp stock. ![](/ubbthreads/images/graemlins/shruggy.gif)
If I remember correctly stock V-10 was 310 HP and 450 lbs, torque new. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
Re: V10 HP PARTS
[Re: redraptor]
#1491622
08/28/13 08:41 PM
08/28/13 08:41 PM
Posts: 767 NW PA
V10nacuda
NW PA
I will put $$ on 450tq & 310 sounds about right.
Loved my 98 QC V10 truck... Kinda wish I could find a low mileage 4x4 without rust!!
Re: V10 HP PARTS
[Re: WO23Coronet]
#1491625
08/29/13 11:24 AM
08/29/13 11:24 AM
Posts: 517 ND
dodgedon
ND
I remember reading an article in a Mopar mag about intake mods on the then current Magnum motors. For the V10 they said to mill a slot in the intake bores at the throttle pad down to the balance hole. This would raise HP in the upper RPM's. I may still have that article...
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
