V10 HP PARTS #1491607
08/27/13 02:39 PM
08/27/13 02:39 PM
OHIO
BUBBAZ572 Offline OP
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
ARE THERE ANY HP PARTS FOR THE V10 TRUCK ENGINE?
HEADS
INTAKE (UPPER AND LOWER)
CAM SHAFT
PISTONS & RODS
IGNITION SYSTEM
ANY BODY KNOW WHAT HAPPENED TO THE PERFORMANCE PARTS THAT WALKER EVENS USED IN OFF ROAD RACING IN THE 90'S?
MY TRUCK CHASSIS DYNO AT 253HP AND 375 TORQUE
BUBBAZ572@YAHOO.COM
Re: V10 HP PARTS [Re: BUBBAZ572] #1491608
08/27/13 02:46 PM
08/27/13 02:46 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
They made a hotter Ignition box for the truck V10 you had to use Premium with it.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: V10 HP PARTS [Re: Savoy1964] #1491609
08/27/13 03:36 PM
08/27/13 03:36 PM
OHIO
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
DO YOU KNOW BRAND?
Re: V10 HP PARTS [Re: BUBBAZ572] #1491610
08/27/13 04:30 PM
08/27/13 04:30 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Just buy a viper for parts.
Re: V10 HP PARTS [Re: 76dodgeboy] #1491611
08/27/13 04:44 PM
08/27/13 04:44 PM
OHIO
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
I TRIED THAT! PARTS WILL NOT WORK
Re: V10 HP PARTS [Re: BUBBAZ572] #1491612
08/27/13 05:39 PM
08/27/13 05:39 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Really! I was always under the impression the truck was a retubed viper motor
Re: V10 HP PARTS [Re: 76dodgeboy] #1491613
08/27/13 05:43 PM
08/27/13 05:43 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
I got mine at a swap meet but it was a chrysler part.
Re: V10 HP PARTS [Re: 76dodgeboy] #1491614
08/27/13 07:20 PM
08/27/13 07:20 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
There is nothing shared between the two except for bore and stroke in the first years.
Re: V10 HP PARTS [Re: BUBBAZ572] #1491615
08/27/13 07:26 PM
08/27/13 07:26 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
HEADS
CAM SHAFT
PISTONS & RODS
IGNITION SYSTEM
ANY BODY WHAT HAPPENED TO THE PERFORMANCE PARTS THAT WALKER EVENS USED IN OFF ROAD RACING IN THE 90'S
BUBBAZ572@YAHOO.COM
There never really was a market to support that engine. It is what it is and you can buy headers redily and that's about it.
You want to be different? Search a company to fab you up a rear turbo kit and customize the PCM.
Re: V10 HP PARTS [Re: BUBBAZ572] #1491616
08/27/13 09:09 PM
08/27/13 09:09 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
WHAT?!?!?! WHAT?!?!?
Re: V10 HP PARTS [Re: Golden-Arm] #1491617
08/27/13 09:12 PM
08/27/13 09:12 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
You could have had a V8.
Re: V10 HP PARTS [Re: stumpy] #1491618
08/27/13 10:13 PM
08/27/13 10:13 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
You should have had a V8.
*fixed it for ya!
Re: V10 HP PARTS [Re: Golden-Arm] #1491619
08/28/13 02:19 AM
08/28/13 02:19 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
There's nothing stopping you from porting the heads, getting a cam reground and putting headers on it, 253 HP isn't bad for a stock truck.
Re: V10 HP PARTS [Re: WO23Coronet] #1491620
08/28/13 07:00 AM
08/28/13 07:00 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
There's nothing stopping you from porting the heads, getting a cam regroups and putting headers on it, 253 HP isn't bad for a stock truck.
something isn't right there...
is it REALLY only 253?
a 5.9L V8 had 250 hp stock.
mine has a cam, intake, headers and a computer re-tune, and I'm putting 285 hp to the wheels.
**Photobucket sucks**
Re: V10 HP PARTS [Re: 70Cuda383] #1491621
08/28/13 08:19 PM
08/28/13 08:19 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
If I remember correctly stock V-10 was 310 HP and 450 lbs, torque new.
Re: V10 HP PARTS [Re: redraptor] #1491622
08/28/13 08:41 PM
08/28/13 08:41 PM
NW PA
V10nacuda Offline
V10nacuda  Offline
NW PA
I will put $$ on 450tq & 310 sounds about right.
Loved my 98 QC V10 truck...
Kinda wish I could find a low mileage 4x4 without rust!!
Re: V10 HP PARTS [Re: V10nacuda] #1491623
08/28/13 08:46 PM
08/28/13 08:46 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
how about a blower---or twin turbos...
Re: V10 HP PARTS [Re: 70Cuda383] #1491624
08/29/13 03:37 AM
08/29/13 03:37 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
It's 253 at the wheels……that's not bad
Re: V10 HP PARTS [Re: WO23Coronet] #1491625
08/29/13 11:24 AM
08/29/13 11:24 AM
ND
dodgedon Offline
dodgedon  Offline
ND
I remember reading an article in a Mopar mag about intake mods on the then current Magnum motors. For the V10 they said to mill a slot in the intake bores at the throttle pad down to the balance hole. This would raise HP in the upper RPM's. I may still have that article...
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: V10 HP PARTS [Re: dodgedon] #1491626
08/29/13 12:51 PM
08/29/13 12:51 PM
dogdays Offline
dogdays  Offline
A couple of turbos would increase power by a lot.
R.
