Re: Rocker arm adjuster replacement
[Re: pacifica]
#1491399
08/28/13 12:03 AM
08/28/13 12:03 AM
Posts: 198 Chester, VA
tobnHisglory
Chester, VA
I'm looking to get a set for my crane gold rockers. Do you mind sharing the cost and the "schooling" they offered? Thanks!
-Reggie tobnHisglory2000@aol.com Former Mopars: 73 Charger - 440/727, 68 D200 Camper Special 383/727, 67 Satellite, 71 Superbee, 73 RoadRunner,2009 Ram Quad Cab Hemi 4x4 Current Mopars: 2005 Ram Quad Cab Hemi 4x4, 73 Cuda FE5 318 manual
[Re: tobnHisglory]
#1491400
08/28/13 06:28 PM
08/28/13 06:28 PM
Posts: 602 N.E.Ohio
pacifica
N.E.Ohio
Cost is $86 shipped for a set of adjusters and lock nuts.
Info wise these adjusters are heat treated on the ball end which helps them resist wear. The threaded area not so much as that would make the metal harder and maybe a little more brittle. This is important because the rockers are aluminum and increase and decrease in size (due to heat) at a different rate that the threaded adjusters do.
Not sure I've explained this properly, but that is my understanding.
Seems as though the original adjusters that came with these rockers were hardened all the way through (my set is 10+ years old).
Anyhow since one broke it is time for maintainance ![](/ubbthreads/images/graemlins/wrench.gif)
