Pulling 4-Speed - How Keep Tailshaft Fm Dumping Fluid? #1491313
08/26/13 09:07 PM
08/26/13 09:07 PM
dart1962_440 Offline OP
Any creative ways to prevent fluid from coming out of the tailshaft when pulling a 4-speed?
I don't have an extra driveshaft yoke or a Mopar trans plug kit. Anything else work that limits fluid loss? Not really looking to drain it if I'm just R&R-ing it.
Re: Pulling 4-Speed - How Keep Tailshaft Fm Dumping Fluid? [Re: dart1962_440] #1491314
08/26/13 09:10 PM
08/26/13 09:10 PM
just south of Green Bay wiscon...
Rob74 Offline
Rob74  Offline
ziplock bag around the tail shaft with either duct tape or rubber bands holding it on hope it helps,Rob
down to just one toy still got my 74 pro street/drag cuda with a best of 10.89@125..i know weak huh?
Re: Pulling 4-Speed - How Keep Tailshaft Fm Dumping Fluid? [Re: dart1962_440] #1491315
08/26/13 09:11 PM
08/26/13 09:11 PM
IN
ahy Offline
ahy  Offline
IN
You covered the usual ways. When I need to pull one without a spare yoke or plug I get plenty of junk rags, a full bottle of shampoo and a quart of gear lube.
Re: Pulling 4-Speed - How Keep Tailshaft Fm Dumping Fluid? [Re: Rob74] #1491316
08/26/13 09:12 PM
08/26/13 09:12 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
NAPA sells a universal plastic cone for sealing the tail shaft. I suspect other parts stores have something too.
Re: Pulling 4-Speed - How Keep Tailshaft Fm Dumping Fluid? [Re: dart1962_440] #1491317
08/26/13 09:14 PM
08/26/13 09:14 PM
central pa
darted1 Offline
darted1  Offline
central pa
if you are working close to the ground (floor) let the drive shaft in the trans when removing it . if on a lift you will need a extra pair of hands to hold the shaft till you have it on the floor etc.have done this many times but now i have a yoke off a drive shaft makes it easier for one person.
ED M
Re: Pulling 4-Speed - How Keep Tailshaft Fm Dumping Fluid? [Re: darted1] #1491318
08/26/13 09:49 PM
08/26/13 09:49 PM
Alberta, Canada
K
krisiesmopes Offline
K
Alberta, Canada
Go to the dealership and ask the tranny guy if he has any plugs in his toolbox from the remans, probably toss you a couple for free.
Re: Pulling 4-Speed - How Keep Tailshaft Fm Dumping Fluid? [Re: TooMany62s] #1491319
08/26/13 10:05 PM
08/26/13 10:05 PM
That's a great idea. It looks like Harbor Freight has one that's worth a try.
Re: Pulling 4-Speed - How Keep Tailshaft Fm Dumping Fluid? [Re: dart1962_440] #1491320
08/26/13 10:39 PM
08/26/13 10:39 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Drain the trans first?
It's a 4 speed, it'd be easier to grunt around too.
Once drained I've used the cap off a spray paint can and some duct tape.
Don't be the exception.
Re: Pulling 4-Speed - How Keep Tailshaft Fm Dumping Fluid? [Re: Supercuda] #1491321
08/26/13 10:41 PM
08/26/13 10:41 PM
NY
Beep Beep Offline
Beep Beep  Offline
NY
I used a zip lock bag with a cable tie, or Harbour Freight sells a universal plastic tranny plug.
Re: Pulling 4-Speed - How Keep Tailshaft Fm Dumping Fluid? [Re: Beep Beep] #1491322
08/26/13 10:44 PM
08/26/13 10:44 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Drain it.. Most likely needs changed anyway...
I am truckless..
Re: Pulling 4-Speed - How Keep Tailshaft Fm Dumping Fluid? [Re: 340SHORTY] #1491323
08/26/13 11:25 PM
08/26/13 11:25 PM
IN
ahy Offline
ahy  Offline
IN
Best idea yet. I've tried the plastic bag... didn't work for me. Still made a mess. I've tried leaving the shaft in. I couldn't get it out from under the car very well and made a mess anyhow.
Re: Pulling 4-Speed - How Keep Tailshaft Fm Dumping Fluid? [Re: ahy] #1491324
08/27/13 12:12 AM
08/27/13 12:12 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Your welcome
Re: Pulling 4-Speed - How Keep Tailshaft Fm Dumping Fluid? [Re: Supercuda] #1491325
08/27/13 12:43 AM
08/27/13 12:43 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
My suggestion is to jack up the back end of the car higher than the front so that the tailshaft is angled upward. This will keep the trans fluid from running out.
Just my $0.02...
Re: Pulling 4-Speed - How Keep Tailshaft Fm Dumping Fluid? [Re: dart1962_440] #1491326
08/27/13 04:44 PM
08/27/13 04:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The plastic cap from a spray paint can works surprisingly well (the kind with the inner ring), especially if you have the rear seal with a dust boot.
