So I flushed this 440 block
#1491252
08/26/13 07:11 PM
08/26/13 07:11 PM
Posts: 5,912 Athens, Greece
Pyper70
Athens, Greece
I did it the backyard way....I pulled the water pump (cast iron) and replacing it with the Mancini aluminum package...I decided to hook up a garden hose to it on both sides, top and bottom. The passenger side of the block had orange stuff come out, was to be expected....The Drivers side had white sediment come out...I kept checking to make sure the oil wasn't being contaminated with water....I am good on that....I went ahead and blew out whatever water was left over with compressed air...
What could the white stuff have been? The coolant that came out from the radiator drain was a dark murky Green...Going to replace it with 60/40 Prestone
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: So I flushed this 440 block
[Re: Pyper70]
#1491256
08/27/13 12:54 PM
08/27/13 12:54 PM
Posts: 27,485 So Cal
autoxcuda
So Cal
Calcium deposits from your tap water.
Use Reverse Osmosis bottled water.
[Re: autoxcuda]
#1491257
08/27/13 02:44 PM
08/27/13 02:44 PM
Posts: 17,923 S.E. Michigan
ZIPPY
S.E. Michigan
Sodium Silicate from coolant additive dropout.
Most brands of antifreeze have silicate additives.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#1491258
08/27/13 03:35 PM
08/27/13 03:35 PM
Posts: 21,854 Kirkland, Washington
Pacnorthcuda
Yep, silicate dropout.
