Re: Stock 4.7/RFE Swap Into 74 B-Body Electrical Details
[Re: DaytonaTurbo]
#149085
11/18/08 04:41 PM
11/18/08 04:41 PM
Are you sure that I would need Ford coils and plug wires with a Ford EDIS system? I'm under the impression that the EDIS would run the stock 4.7 coils on the plugs with nothing changed coil wise nor any need for plug to coil wires.
As far as transmission controller I was thinking this would do it.
http://www.powertraincontrolsolutions.com/content-4.html
The info mentions the 45RFE by name and they have a harness for it as well.
As a side not, this appears to be the same box Keisler is using to control their OD autos in their swaps.
Not sure, I have no practical experience with the ford edis system. I've been setting up my efi controller to run the stock distributor just because for me, that was the easy way out. Not sure if edis would run your COP or if you would have to use the edis style 8-in-1 coil w/ conventional plug wires.
If that aftermarket trans computer will work for your setup, you may be in business in that regard. But for the $$$ you'd be paying for it, you'd be better off just getting a RH trans and rebuilding it. I tried that website link, but it was going so slow I just gave up.
Also, even a manual trans dakota engine control computer will require a speed sensor. Speed sensor controls has an effect on many engine control functions on the OEM comptuers. I've seen the maps for the 80's FWD mopar ecu's, and it would take a substantial amount of recoding to phase out the speed sensor even in a manual trans setup. Also, some manual trans controllers have trouble with idling in gear with the load placed on them by and auto trans. A regular auto trans computer will have a signal sent to it telling it the auto trans is in gear, and then it knows to bump the idle speed up a little to compensate. I've heard of some manual trans comptuers stalling the engine during decel/idle when hooked up to an auto trans. And that was with the 80's programming, nevermind how needlessly overcomplicated that was, I can't imaging how nasty the newer coding is.
That's good info on the speed sensor. I think your right, it would be tough to create a fake signal without a VSS or something like it. If it would even be possible to flash out the need for the VSS, I don't know how well the engine would run afterward anyway. I have read the speed sensor does help the ecm with idle on deceleration so what your saying makes perfect sense. Nice car in the sig by the way.
#149086
11/18/08 05:22 PM
11/18/08 05:22 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
I see what your are saying on the VSS sensor and using a man trans controller with an auto. I think you would be good though. I am pretty sure this is what alot of 5.7 hemi guys are doing. I would call Dave at B&G Chrysler, he is one of the few that really knows flashes. He is up in Michigan.
Justin
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
[Re: DaytonaTurbo]
#149088
11/19/08 12:25 AM
11/19/08 12:25 AM
Posts: 2,304 WI
RestoRick
WI
This is for my 2002 4.7L w/45RFE: VSS Here's a picture of the trans... I believe the VSS is towards the rear near the tailshaft housing joint. (I'll take a look at it tomorrow.) Not sure if the '02 is like my '99, but that truck has the ABS sensor in the rear axle. IIRC, the '02 has a separate 'puter for ABS. (I'll look through my FSM tomorrow.) Rick
[Re: RestoRick]
#149089
11/19/08 11:38 AM
11/19/08 11:38 AM
VSS
Rick
Hi Rick,
Yeah, since I have never seen the truck that this came out of I have had to assume that the VSS was in the rear end but that may not be correct...
The transmission should have an input and an output speed sensor on the driver side mid way up the case. The input is near the front of the case (before the bell) and the output near the rear of the main case just ahead of the rear tail housing. I don't have a good pic of the rear tail case. It sure would be nice to know the VSS was all taken care of right on the tranny.
If the VSS is on the tail shaft of the trans, then does that mean that the RFE conversion tail housing that allows the speedo to work via a cable could not be used since the VSS is key to engine non-limp mode? That could mean an electronic speedo is mandatory for this project eh?
#149090
11/19/08 08:41 PM
11/19/08 08:41 PM
DaytonaTurbo
Manitoba, Canada
Possibly. I know on the 80's mopars I've worked with, many years used a VSS with a cable driven speedo. The speed sensor just has an output nub you can screw a speedo cable onto. Newer stuff probably runs a different speed sensor than the 80's-90's mopar cars, but it's something to look into.
#149091
11/22/08 04:58 PM
11/22/08 04:58 PM
#149092
11/23/08 01:47 PM
11/23/08 01:47 PM
I sent this back to BPE. I hope I will get a yes or no back on the original flash questions.
Why a 4.7? Why did the original owner special order the Charger powder blue, slap stick with a slant six from the factory? I don't mind keeping the car an odd duck. Besides, I can get the whole 4.7-45RFE drive train for $600 including everything under the hood.
I'm a computer programmer by trade and this is not my first EFI project nor my first complete vehicle re-wire...
This conversation is getting off track. So can you flash the computer to work within the threads original criteria for success?
Thanks,
I still have not heard back from BPE. I have ordered parts from BPE in the past and was very happy with my order and their service, however not so much on getting information about a possible ECM flash...
#149093
11/24/08 01:44 AM
11/24/08 01:44 AM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
I have a complete 4.7L from my 2000 dakota sitting here that I am planning on putting in my 71 valiant after I finish putting the SRT10 motor in the dak. I'm planning on using the factory computer and engine wiring harness and I don't think there will be to much of a issue making the other neccessary connections. However my dakota was a manual trans so I don't have the transmission control issues. I'm planning on sticking with the A833OD thats in the car now when I put the 4.7L in. I have all the wiring diagrams that I can send to you if that might help you out. -Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
[Re: blown340]
#149094
11/24/08 07:05 PM
11/24/08 07:05 PM
-Jon
Thanks Jon I appreciate the offer. I may take you up on it in the near future.
WOW!!! A SRT-10 motor in a Dak eh? Nice project
#149095
11/24/08 09:24 PM
11/24/08 09:24 PM
blown340
Walnut Creek, CA
No prob, if you ever need them just send me a PM and remind me what we were talking about.
-Jon
#149097
11/25/08 01:57 PM
11/25/08 01:57 PM
I heard back from Mopar_Rich regarding 4.7 and FAST EFI From: Mopar_Rich "I just heard from my contact at Mopar. This is what he said: *************** Cam sensor is mounted to right cylinder head, towards the front of the motor. It goes in upside down, from the bottom up. One 10mm head bolt holds it in. The crank sensor is on the same side (right) down by oil pan. Also a 10mm head bolt. *************** So if your engine has both these sensors, then running a FAST system would be easy!" Does anyone know for sure if the 4.7 has these sensors? All years or just some? I don't have access to the engine at the moment so I can't confirm.
#149098
12/01/08 03:54 PM
12/01/08 03:54 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
I’ve become a bit interested in this thread too, I was planning for a future 5.2 Maggie installation with a Megaqsquirt, but the 4.7s are starting to show up in the cheap Pickapart junkyards near me. My questions below are a bit of a hijack to the OP but I think it’s relevant to the thread overall. Some questions I have: • What years have the throttle body cable-actuated? I’m finding conflicting info on this. • Is the fuel rail a returnless-type for all years? Returnless might pose some additional complexity for a carb-car retrofit with an aftermarket ECM, it requires PWM to run the fuel pump. • Anyone have any insight on the motormounts? Are they similar to anything we are already familiar with? • Any Service Techs have a general breakdown by production year of what changes/improvements were made? Any engines more desirable or easier to retrofit? • Supposedly a twin-plug head is coming (or already in production). Could these heads be installed with the older intake to use a cable-style throttle body??? According to this article it went to drive-by-wire in 2007: http://www.allpar.com/mopar/47.htmlAccording to this article perhaps it was in 1999? http://dodgeram.org/tech/gas/Cammer/4_7_v8.htmlHere is a BBK cable-drive throttle body: http://store.summitracing.com/partdetail...mp;autoview=sku
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: Fury Fan]
#149099
02/24/09 10:54 PM
02/24/09 10:54 PM
I already installed a 2004 5.7 Hemi/45rfe trans in my Javelin. I used all the electrical components from the donar Dodge Ram truck except for the ABS controller, rear axle and I also deleated the air bags. I did reuse the truck dash and all the truck wiring. My car runs and drives but I have no speedo. The Explorer 8.8 rear I am useing has an 8k VSS, but without the ABS controler, the signal has no where to go. Can I just use the electronic portions of an ABS controler and deleate the pump and brake lines? The 8.8 disc brake rear is a populal swap rear and will give you the needed VSS signal. Speed & Performance told me it would work but I didn't know about the ABS controller issue at that time.
