Center force clutch question
#1490610
08/25/13 07:02 PM
08/25/13 07:02 PM
Posts: 343 Pennsylvania
hemi67
Pennsylvania
Just removed a Mcleod Borg and beck clutch in my 67 B Body due to a broken pressure plate spring. I decided to go with a Center force dual friction. After installling it, I removed the overcenter spring under the dash as instructed by the clutch manufacturer. The clutch works fine and the trans shifts smoothly, but the feel of this clutch is strange. It is not much easier to depress than the Mcleod, but whats annoying is how it releases. When you start to release it, it gets to a certain point, just about where it begins to grab, and becomes somewhat difficult to hold almost forcing you to release it the rest of the way rather quickly which causes the car to jerk obviously. It seems to have a much smaller window of "slippage" if that makes any sense. The Zbar is the correct one and is new as well as all of its components. Greased and installed correctly. The spring on the clutch fork does hold the clutch pedal up completely when released. I have plenty of free play and the trans shifts smoothly. Not sure where to go from here. Almost wonder if I should put the overcenter spring back in??? Will that make it worse?? ![](/ubbthreads/images/graemlins/chargerwork.gif)
Re: Center force clutch question
[Re: hemi67]
#1490614
08/25/13 07:58 PM
08/25/13 07:58 PM
Posts: 105 Ontario, Canada
D149
Ontario, Canada
I have the same problem with my Center Force Dual Friction in my Road Runner. I was told I have to put a clutch pedal "stop" to prevent the diaphragm from going over center. Unfortunately, that means the pedal will have to stop just after the clutch releases. To me, this will make it very difficult to drive. So, I am living with the crappy feel and jerky starts until I can afford a Mcleod! Just my ![](/ubbthreads/images/graemlins/Twocents.gif)
1968 Valiant Signet 4dr. 273 4spd 1969 Road Runner 383 4spd 1969 Barracuda 318 auto 1970 Dart Swinger 340 4spd 1975 Cordoba 400-4bbl 1988 Caravelle 318 Auto 1999 Dakota R/T 2000 Viper GTS 2001 Ram 2500 Diesel 6spd 2018 Dodge Challenger GT (Winter beater!)
[Re: hemi67]
#1490615
08/25/13 08:13 PM
08/25/13 08:13 PM
Posts: 26,032 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Try the "feeler gauge" method of adjusting the clutch, put a stop on the pedal so that the disc clearance is no more than .060".
[Re: hemi67]
#1490616
08/25/13 08:47 PM
08/25/13 08:47 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
The CFDF is a great buy and a good setup. I've run this combo for many years. It does have an "on-off" feel. You just have to drive it and get used to it. After a bit of driving, you'll grow to love it. ![](/ubbthreads/images/graemlins/drive.gif)
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: 68CoronetRT]
#1490619
08/26/13 12:24 AM
08/26/13 12:24 AM
Posts: 10,559 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have had just about every clutch out there EXCEPT Centerforce. I actually have a new Centerforce that I was going to try this year but I decided to keep my Hays Mark XII race clutch in the car til after the Norwalk stick race. Gus ![](/ubbthreads/images/graemlins/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 68LAR]
#1490620
08/26/13 12:31 AM
08/26/13 12:31 AM
Posts: 4,437 Omaha Nebraska
Brian_wo
Omaha Nebraska
On off feel? Put mine in ten years ago and never noticed that,just got the car back with the same clutch in it and it drives just fine.
who is that guy?
[Re: Brian_wo]
#1490621
08/26/13 09:07 AM
08/26/13 09:07 AM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
My CF has been in 12 years.Its one great setup.You do have to get used to it.Mine still hooks like the day it was installed.Rocky
Chrysler Firepower
[Re: 5spdcuda]
#1490626
08/27/13 05:13 PM
08/27/13 05:13 PM
68LAR
South Park, Pa.
I've posted on this topic before, but I suppose since it's not in the archives it's bound to come up again from time to time. It is NOT necessary to remove the overcenter spring when installing a diaphragm clutch IF you also install a positive pedal stop. A diaphragm clutch spring is basically a big Belleville washer. It is possible to over center one and then the clutch will hang up. If you do choose to remove the factory overcenter spring two things will happen. First the clutch pedal effort will feel similar to that of a Borg & Beck with the spring in place. Second you will have to fabricate some sort of return spring to keep the throw out bearing from constantly riding on the clutch fingers when the clutch is released. Personally I think it's easier to use the factory spring since it's already there and it makes for a nice light pedal similar to most modern cars. I make an adjustable stop for my own car. I simply weld a connecting nut from the hardware store to the pedal about two inches or so above the pedal pad and screw in a bolt with the head facing the firewall. Use a jam nut to keep it in place when you adjust it. You need to adjust the bolt so you have about an inch or so of travel past full release. All of this should cost roughly $2.00. As for the on/off feel the OP refers to, I don't think it's all that surprising since he has the dual friction disc and Centerforce unlike McCleod or Sachs uses centrifugal weights to apply extra force to the disc. If he had a full organic disc it would probably have a smoother more progressive feel.
With so many using the Centerforce dualfriction, some having issues and more not having any issues, I have to wonder if those having issues are doing something different and maybe wrong as compared to those that are NOT having issues. Personally I have found that doing as Centerforce recommends works best. Remove the over center spring and install a return spring at the bell housing. No pedal stop is recommended and I personally don't use one. I have to wonder again, how installing the same clutch, in the same type of car, can have different results????? ![](/ubbthreads/images/graemlins/drive.gif)
