Page 2 of 6 1 2 3 4 5 6
Re: R5P7 a great bargain for drag racing (long) [Re: LAD 524] #1490483
08/28/13 10:24 AM
08/28/13 10:24 AM
Out West
408strokerdart Offline
Out West
Great info Leon.
Does EEI have a website, how did you source that block?
Here......let me google it for you.
http://www.ernieelliott.com/
Re: R5P7 a great bargain for drag racing (long) [Re: 408strokerdart] #1490484
08/28/13 10:54 AM
08/28/13 10:54 AM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
I have a question or more a hypothetical.
Lets say I purchased a used engine, resize the valves and throat to match, install a drag racing specific cam, and move over to a sheet metal manifold and 2x4's up top, what type of power am I making at 10k rpm with a 358?
Adriel Paradise
Substation Design Engineer III
Re: R5P7 a great bargain for drag racing (long) [Re: Adrielp] #1490485
08/28/13 04:50 PM
08/28/13 04:50 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
You are asking close to what I am going to be building or better yet my engine builder(Scotty Brown) is. In our talks he has mentioned upping the compression to 16:1, going to a reliable roller cam, using the M&M sheetmetal style cast intake and the appropriate carbs, I am thinking the new Holley HP or the new smaller dominatiors.
I was told to looks somewhere in the 950-975 range. But he has always been conservative in his estimates. This is not set on kill either. The car is being built for an index class. I want to be about 2 tenths faster than the index to account for weather and altitude changes. If it is faster so be it.
The M&M style vs sheet metal is a cost vs gain issue. Sheetmetal you are going to drop about 3000-4500 for a good intake. The M&M unit plus porting is about 2k. you will gain about 20hp maybe a little more with the sheet metal. Car set on kill, then sheetmetal all the way.
This info is what my engine guy has been telling me. He has my motor now. Work is coming slow as I have the chassis being built and the body on the other car all being done at one time.
I will be using a 7 or 8” convertor, Bruno and Liberty Extreme 4spd. The 4spd is because the class calls for 2-3 speed auto or 4spd manual.
Leon an update as you know the most of what I am doing, the struts are ordered, mock up block, headers and few other components are there. The chassis guy was super busy and I told him to move me to the end of the line.
Re: R5P7 a great bargain for drag racing (long) [Re: mopartony] #1490486
08/28/13 06:49 PM
08/28/13 06:49 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
If you buy a used set of heads it is just like any other used heads. It is not practical to cut guides and weld and move ports around on used heads. That is not the way to go with used heads IMO. However get some raw castings and have at it.
Bob tried the M&M intake and it had huge cylinder to cylinder issues. The single four 2819 made more power. I know of several Chevy guys who don't like the M&M either.
Porting on an existing head and going to tunnel ram is not going to net 950-975 IMO. My current engine dynoed at 903HP with Q16. I can tell you I have ran it with the trick carb and Q16 as well as my carb and 112. There is not much ET and no MPH difference. In my car this engine is not making much more man 850 HP.
EEI has a drag engine with tunnel ram and two fours for sale. I don't know what he made for HP with the 358 in this form.
A Bruno liberty combo is what these engines are going to like.
I got a little secret coming out soon for testing. Then over the winter it will get some changes and really see what can happen.
Re: R5P7 a great bargain for drag racing (long) [Re: Leon441] #1490487
08/28/13 11:55 PM
08/28/13 11:55 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Your "great bargain" anology makes me chuckle.... but then again, I thought I'd never actually order a brand new block and end up with some W8 heads either... Great read and look forward to more results!!
Re: R5P7 a great bargain for drag racing (long) [Re: J_BODY] #1490488
08/29/13 01:50 AM
08/29/13 01:50 AM
in a chair
mopartony Offline
mopartony  Offline
in a chair
Leon, is core shift the issue with the cyl to cyl lining up? If so looks like I will need to go to a sheet metal intake.
The rules say 2x4 so I have to run 2.
Re: R5P7 a great bargain for drag racing (long) [Re: mopartony] #1490489
08/29/13 01:53 AM
08/29/13 01:53 AM
NC
HMcCandless_Jr Offline
NC
A friend of mine put one of these in a 235wb Race Tech Dragster, first pass it went 4.83 with a 410 gear and a 16x33 tire, its on cruise control, needs more gear and a smaller tire.
Re: R5P7 a great bargain for drag racing (long) [Re: mopartony] #1490490
08/29/13 08:19 PM
08/29/13 08:19 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
No, there is no core shift issues that I am aware of. The issues were with the EGT's from one cylinder to the next running the tunnel ram. The intake was ported for the P7 heads. It's just hard to compete with NASCAR developed intakes. Not saying the M&M will not work it's just the experience I was told about, it didn't work as well and had cylinder to cylinder differences in EGT meaning some were rich others were lean.
Leon
Re: R5P7 a great bargain for drag racing (long) [Re: Leon441] #1490491
08/31/13 11:26 AM
08/31/13 11:26 AM
Charleston, SC
SCDaytona Online content
SCDaytona  Online Content
Charleston, SC
Leon, I give you a lot of credit trying to make this work for you. As for why Chevy guys build those SB2 motors is they are cheaper to build. A dart block is no where near $7500 or from what others have said, a stock block will work as well. Plus making over 1000 Hp is pretty common as well. Still waiting to see a P7 make that power. Anyways, if Leon puts a Pro Flite behind his motor, it will definitely come to life especially in the 60 foot and that gain will show up on the top end as well. I've spoken with him before and he's one dedicated racer.
Re: R5P7 a great bargain for drag racing (long) [Re: Leon441] #1490492
08/31/13 03:29 PM
08/31/13 03:29 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
Leon, True there is a ton of R&D in the NASCAR intakes, the whole engine is highly refined for every HP and endurance.
Do you know if M&M ported the intake or did someone else?
Just wondering.
One thing on my post above. The Q16 in the motor as it is, wouldn't help but I am going to go to 16:1 compression, this should help the HP.
Did you up your compression at all?
Re: R5P7 a great bargain for drag racing (long) [Re: mopartony] #1490493
09/02/13 03:39 PM
09/02/13 03:39 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
The EEI aluminum block is $7,500. That is with Jesel Keyway bushings, head studs, roller cam bearings, align bored, bored and honed to size, and square. The Dart block does not even compare according to the sources I have talked to that build both engines for circle track.
You can still pickup cast iron blocks cheap but are limited by the small mains and displacement if you plan on power adders that is a big deal.
Tony the M&M intake was ported by Dart. The ones I have seen on SB2's were ported else ware and did not make the extra power expected either.
We will not be needing a proflite. Stroke and weight loss are in the near future.
I just bought some more stuff. The spare parts were really nice and just need cleaning up. The candied Apple I was going for can handle a lot of improving on some small issues. The previous owner swapped parts and paid no attention to intake ports matching or anything of the sort. Bound to be some room for improvement. I already have to swap pans. Remove the heads and check everything out so. Just a few more bolts and some huge changed can be made. Just don't know how patient I will be. I may come out in a few weeks with close to what I brought home. Then again things may just turn to a nitrous eating dragon that plans to take no prisoners.
I just have a couple concerns like the steel rods I hate to replace just because they are steel. Know very little about the Mahle pistons. The cam is definitely too small. But, is there time to get a cam ground and I know little about what a P7 combo wants in a nitrous cam. I tried at least 10 different combinations on cams pistons and compression on my W8 before I was satisfied.
And there is a local Outlaw Street race coming up that I would not mind trying out. The track is going to be worse than any highway, that I can guarantee with no prep. Good thing is there are no BS rules that have nothing to do with street legal like some of the others.
Leon
Re: R5P7 a great bargain for drag racing (long) [Re: Leon441] #1490494
09/03/13 06:01 PM
09/03/13 06:01 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Thank you for this thread Leon, and please keep us posted on what you decide. I would love to hear about this street style race, that's kinda my cup of tea.
Re: R5P7 a great bargain for drag racing (long) [Re: SpareParts] #1490495
09/03/13 06:06 PM
09/03/13 06:06 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Good info here
Re: R5P7 a great bargain for drag racing (long) [Re: Al_Alguire] #1490496
09/05/13 04:45 PM
09/05/13 04:45 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
Well it makes no sense to start making changes right off the start. So I am putting my pan, oil pump, water pump, and motor plate on the engine and sit it in the whole.
I am looking for a 6,000 stall 8" Turbo spline PG converter just to try for now. My converters or either too loose or way too tight.
Leon
Re: R5P7 a great bargain for drag racing (long) [Re: Leon441] #1490497
09/05/13 05:19 PM
09/05/13 05:19 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
Question - Since Dodge quit NASCAR have they quit making these?
Re: R5P7 a great bargain for drag racing (long) [Re: SRT6776] #1490498
09/05/13 09:01 PM
09/05/13 09:01 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
Quit. Yes they quit the R5 and P7 stuff several years ago. But, there were around 1,000 engines built. Ernie Elliot alone built several 100's for Ganassi.
Re: R5P7 a great bargain for drag racing (long) [Re: Leon441] #1490499
09/05/13 09:49 PM
09/05/13 09:49 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
The newer version is the R6 P8.
Re: R5P7 a great bargain for drag racing (long) [Re: TrWaters] #1490500
09/06/13 09:13 AM
09/06/13 09:13 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Has a 4.5" bore sapcing and shares nothing with the R5/P7 engine, the block is also a closed deck
Alan Jones
Re: R5P7 a great bargain for drag racing (long) [Re: TrWaters] #1490501
09/06/13 10:52 AM
09/06/13 10:52 AM
Home
SRT6776 Offline
SRT6776  Offline
Home
Cool
RE: The R6P8
“We are excited to launch our new “closed deck” engine block with Penske Racing Engines for the Sprint Cup Series at Martinsville this weekend,” said Dave Bailey, SRT Motorsports Engineering. “We are very pleased with the performance and durability of our previous ‘open deck’ block, but are introducing design changes to help improve head gasket life and future capability for power increases. The post machining and processing time at Penske’s engine shop will be significantly reduced. We will also take advantage of weight improvements that come along with the base block material changing to “compacted graphite iron” similar to the other manufacturers. We worked closely with NASCAR to ensure the changes are compliant and have competitive parity.”
I imagine these are pretty rare though as that quote is from 2012 and they hung it up at the end of the 2012 season (after winning the Championship with the engine)
Re: R5P7 a great bargain for drag racing (long) [Re: SRT6776] #1490502
09/07/13 11:28 AM
09/07/13 11:28 AM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
I have accumulated a lot of extra parts. Need to go through and sell all the stuff I no longer need. Heads, valves, springs, valve covers, crank, rods, lifters. They are asking some big prices for some of these parts now.
Leon
