Page 1 of 3 1 2 3
Vibrating 360 #1490375
08/25/13 01:52 PM
08/25/13 01:52 PM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
I traded some parts and got a fresh 360. The guy I got it from didn't know much about it but he gave me the phone to the guy that last drove it, he had it in his 70 Challanger with a 4-spd behind and he said the engine was strong and fun. He bought his Chally with the engine in it and the seller said it was rebuilt but didn't know much more.
I put it in and took a converter from my shelf that came from some 360 (with two weights on). It vibrated badly so I thought it must have been internally balanced when rebuilt, so I took of the weights and thought everything should be fine again, but it still vibrates... Not so bad as it did with the weights, but too bad to be good.
Any ideas?
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
Re: Vibrating 360 [Re: HP2] #1490376
08/25/13 02:05 PM
08/25/13 02:05 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
Did the damper have an offset weight when you got it?
The LA and Magnum have different offset weights, maybe the unknown converter was from the wrong one?
Were the two weights you took off of the converter on the sides or the flat that goes against the flex plate? My LA 360 converter has only one large for the external balance weight, but a couple of small thin weights on the sides which are to initially bring it to zero balance like balancing a tire. I've seen people confuse the different weights and their purposes.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Vibrating 360 [Re: Michael Ecks] #1490377
08/25/13 02:16 PM
08/25/13 02:16 PM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
Embarrassing, I did not look on the damper I just took for granted that a 360 needs a weighted converter I have very little experience from smallblocks. How do you see the difference between the dampers?
The only weights on the TC was two rectangular on each side of the drain plug.
71 Duster 340
Re: Vibrating 360 [Re: HP2] #1490378
08/25/13 02:19 PM
08/25/13 02:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
360's are external balance and are weighted on both ends of the crank.
Also as noted LA 360 and Magnum 360's are weighted differently.
Re: Vibrating 360 [Re: JohnRR] #1490379
08/25/13 02:25 PM
08/25/13 02:25 PM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
I was wrong, I had a picture of the TC and as you can see it has a light weight on the side
71 Duster 340
Re: Vibrating 360 [Re: HP2] #1490380
08/25/13 02:39 PM
08/25/13 02:39 PM
Columbus, GA
Columbus, GA
sorry, I'm doing this on my phone now or I would post some pics. An early LA 360 damper will have a raised oblong weight in front of the main round body of it, late LA 360 and Mag 5.9 will have a deep recess on one side of the round damper ring. If the engine had either as delivered you need an offset weighted converter too.
From the pic you posted it looks like that weight is an initial neutral balancing weight on the outside circumference. But again, I am in my phone. I want to say my offset converter used about a 1" by 3" long weight that was almost as thick as the pads that the flex plate bolts go into.
Sounds to me like you just need to verify what if any external balance you need and get the right converter or offset weight b&m flexplate.
Re: Vibrating 360 [Re: Michael Ecks] #1490381
08/25/13 04:49 PM
08/25/13 04:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Correct, the weight in the pic is a mass balance weight not an external balance weight which would be attached to the engine side of the converter.
Re: Vibrating 360 [Re: Michael Ecks] #1490382
08/25/13 05:13 PM
08/25/13 05:13 PM
The weight on the side is never touched. If you took off the 2 big weights from the front flat face & it still vibrates then I'd get another torque converter as you have now tried it with the weights on (external balanced) & with the weights knocked off (neutral balanced) & no go either way so unless there's a balancing bobweight difference between a neutral flywheel and a neutral TC and or if there's a difference between an external flywheel and an external TC & I dont think there is then it has to be the TC & the only difference from when he had it & it ran smooth & now that you have it & it dont run smooth is that it had a flywheel & now it has a torque converter. It may very well have been still externally balanced like OE (& most hotrodded 360's are) & now just needs the correct externally balanced converter which if the front dampener is the (360) offset unit then I think that's the case (external balanced). Holler how it turns out. EDIT external 360 on the right side/neutral 318 on the left. You wouldn't think they used mag parts here which skews things since as said the externally balanced 5.9 (360) mag & non mag (early regular 360) externally balanced TC's are weighted differently from each other even tho both are externally balanced & in addition you have tried it with the weights on & off & no success. post what you have for the dampener. A 360 could have been neutral balanced with the offset dampener but people usually go with a neutral one if they are going to the trouble (& $$$) to neutral balance a 360
Re: Vibrating 360 [Re: HP2] #1490383
08/25/13 06:38 PM
08/25/13 06:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
hopefully you didn't remove that weight .
Re: Vibrating 360 [Re: RapidRobert] #1490384
08/26/13 05:03 AM
08/26/13 05:03 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
I took a close look at my damper and it looks like the neutral damper to the left on your photo.
I agree in all you say, it all sounds reasonable, so what I have is an internally balanced 360 with a bad converter. Right?
71 Duster 340
Re: Vibrating 360 [Re: JohnRR] #1490385
08/26/13 05:16 AM
08/26/13 05:16 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
Of course not!
71 Duster 340
Re: Vibrating 360 [Re: HP2] #1490386
08/26/13 05:18 AM
08/26/13 05:18 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The LA 360 balance weighted converters that I have seen usually look like a rectangle with the top 2 corners cut off.
Also, I have seen 360 balancers that look like the 273/318/340/383/413/440 steel crank-neutral balancers with that recessed ring EXCEPT that there is a raised section within.
Re: Vibrating 360 [Re: Kern Dog] #1490387
08/26/13 06:34 AM
08/26/13 06:34 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
Mine were 'about a 1" by 3" long weight that was almost as thick as the pads that the flex plate bolts go into' just like Michael described them.
71 Duster 340
Re: Vibrating 360 [Re: HP2] #1490388
08/26/13 10:03 AM
08/26/13 10:03 AM
I took a close look at my damper and it looks like the neutral damper to the left on your photo. so what I have is an internally balanced 360 with a bad converter. Right?
Maybe. There would be no reason for him to swap dampeners when he sold it so with it having a neutral dampener we'll go with that not being swapped so it would APPEAR that it has been neutral balanced especially with the described history of it being hotrodded and the 1" x 3" weights (2) on either side of the drain plug denotes an external TC but the rub is is that you knocked them off to make the TC neutral & still no go (tho it was better) & you'd think that would have taken care of it if it just needed a neutral TC. To k.i.s.s. I'd suggest getting another converter (nuetral) & see what happens. Still no go I'd put an offset dampener on the front & a weighted converter in back but I see no reason he would have changed the dampener so I dont think it'll go that far. & worse case STILL no go after doing all that if you do all that then the crank/dampener(s)/TC(s)/1 piston/rod assy with rings bearings would have to go to your crank man to spin it/check balance to find out WHICH dampener/tc combo it needs to bring it into balance. Holler how it turns out. Very likely another neutral TC will take care of things. It has been balanced & we just need to find out what it needs front & rear
Re: Vibrating 360 [Re: RapidRobert] #1490389
08/26/13 10:54 AM
08/26/13 10:54 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You never answered the question ... is it an LA 360 or a Magnum 360 ?
You need to find out who rebuilt and find out what they did inside there , you could be swapping parts forever chasing this down.
Re: Vibrating 360 [Re: JohnRR] #1490390
08/26/13 02:02 PM
08/26/13 02:02 PM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
Sorry, but I don't know how to determine what it is...
EDIT
I called the previous owner and he says it is an LA engine, says he think it is a crate engine but doesn't know where it came from. I will try to get a hold of the guy who last drove it and try to get some more info.
71 Duster 340
Re: Vibrating 360 [Re: HP2] #1490391
08/26/13 02:06 PM
08/26/13 02:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Well you need to figure that out or you are never going to figure this out.
Does it have 5 bolt or 10 bolt valve covers , though you can swap those covers around ...
Can you look in the oil fill hole and see a the rockers , are they shaft mount or pedestal ?
Re: Vibrating 360 [Re: JohnRR] #1490392
08/26/13 02:30 PM
08/26/13 02:30 PM
dogdays Offline
dogdays  Offline
I, Carnak, will tell you your problem without even reading through RapidRobert's incredibly dense spewing wordforest.
Before you do anything else, find out what motor it is. Look at the front of the engine directly under the driver's side cylinderhead and find the engine ID number. Post that number here.
FORGET all talk of an internally balanced 360. If it had been done, someone would remember the $500+ balancing bill. It is NOT CHEAP to internally balance a 360 with stock internals. You need at least a couple slugs of Mallory and probably a lot more, and at $100 an inch it's EXPENSIVE! This is one case where it is definitely easier said than done.
Secondly, a 5.9Mag motor doesn't have a balance weight on the torque converter, it has the factory imbalance for the rear of the engine built into the flexplate.
Third, your picture shows a neutral balanced torque converter, never came behind a 360.
BUT, my "CHMSL third eye" tells me you have an LA 360. The "out-of-balance 360" post is probably the most common one in the whole history of Moparts.
It's possible that whatever doofus assembled the engine didn't know that the 318 damper and 360 damper were not the same. So check out that front damper and make sure it's for a 360. Clues are posted above. However, most engine shops don't have a pile of Mopar engine stuff lying around to mix up.
Once you have figured out that it's correct, and 2:1 it probably is, get an unbalanced flexplate (B&M is one source) for mounting a neutral balanced torque converter to an LA 360.
At this point your vibrating 360 problems should be over.
R. (Carnak)
Re: Vibrating 360 [Re: dogdays] #1490393
08/26/13 02:33 PM
08/26/13 02:33 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Cute....
Re: Vibrating 360 [Re: dogdays] #1490394
08/26/13 05:36 PM
08/26/13 05:36 PM
Hey Dog after all that (literary) effort & you didn't even read thru it. That hurts my feelings bro . yes I was a bit wired on that one
Page 1 of 3 1 2 3
