Re: GoPro Video of Super Stock Springs in Action
[Re: Dodgem]
#1490249
08/25/13 11:56 AM
08/25/13 11:56 AM
Posts: 5,160 Texas
dannysbee
Texas
Looks like its working good. What does it 60'? What is the et? I was watching it on my phone so detail is not the best. Are the rear shackles getting close to running out of travel? Could we see a couple of pictures of the car and under hood?
Getting old just means you were smarter than some and luckier than others.
[Re: oldtimer5151]
#1490253
08/25/13 04:59 PM
08/25/13 04:59 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Cool video thanks! I got a go-pro for christmas and have been thinking of cool things to video. I need to add the suspension to the list.
68 Barracuda Formula S 340
[Re: oldtimer5151]
#1490254
08/25/13 05:04 PM
08/25/13 05:04 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Thank You for the video. Stop the video about 3/4 way thru, and you will see the rear end turn upward enough to see the yoke. I would install a pinion stop, snubber, and clamp the front and rear springs. The operating angle between drive shaft and pinion should be no more than 3 degrees at any time.
Tree'd Had to do this on my Challenger w/SS Springs
Rickster
[Re: sixpackbee]
#1490257
08/25/13 10:40 PM
08/25/13 10:40 PM
Posts: 13 Novi, MI
M_Delahanty
Novi, MI
To answer some of the questions. The car 60 ft's 1.39 to 1.43 depending on the track. That's with a real 727 - no Pro-Trans. Car runs 10.40-50's. Wheels - 10" w/ 5.5" backspacing. That backspacing is needed to keep the sidewall from hitting the inner fender. Using Hoosier C07 Radials w/ at least 20.5 lbs of air. And wrinkle is lost ET. Photos can be found at this link along w/ other stuff. Click thru them to find the Max-Wedge shots. http://classracer.com/classforum/album.php?albumid=107&pictureid=5808And another in car shot of a good close race. Here are the numbers: - Both cars dialed 10.47 - Reaction times - Ben .0008 Mike .0162 - Finish line - Ben 10.461 Mike 10.4704 http://www.youtube.com/watch?v=WeH--8lLFSg
[Re: M_Delahanty]
#1490258
08/26/13 12:10 AM
08/26/13 12:10 AM
Posts: 6,146 Melbourne , Australia
LA360
The pinion wond up is very telling, these sports cameras are worth their weight in gold for finding things like that.
Alan Jones
[Re: Dodgem]
#1490260
08/26/13 11:55 AM
08/26/13 11:55 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Great looking car and video. I'd be a little concerned about the axle windup though. It looks pretty severe. With the extension you're getting, a snubber wont help much. Even if its right against the floor static, it would be 6" away from anything once you need it.
[Re: M_Delahanty]
#1490261
08/26/13 01:48 PM
08/26/13 01:48 PM
Posts: 5,160 Texas
dannysbee
Texas
Mike thanks for your answers to my questions. Love your car. Are the sliders that replace the rear spring hanger legal in stock. Again neat car.
[Re: 72sat]
#1490265
08/27/13 09:45 AM
08/27/13 09:45 AM
Posts: 3,060 Western New York
sixpackbee
Western New York
I little spring deflection at the intial hit is not a real killer. When the springs return to their regular form that energy helps to plant the tires a few feet out. The car does look like it needs to pitch rotate a little better but overall looks like most early b body stockers.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
