Page 3 of 3 1 2 3
Re: Soooooo close to the 9's!!!!! [Re: 6bblFLASH] #1490197
08/28/13 06:59 PM
08/28/13 06:59 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
It is pretty amazing that you can just dial this thing up and down. I made a pass on 10psi right before the 10.08 pass. It went 11.22@121mph, smooth as silk. Crazy that the same car can run a full second faster with a few key strokes on the laptop.
I would love to try leaving in 2nd, but the trans brake only works in 1st gear.
Re: Soooooo close to the 9's!!!!! [Re: dizuster] #1490198
08/28/13 09:16 PM
08/28/13 09:16 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Dizuster, What were your short times? We only run 1/8 mile down here in the south and I cannot relate to the 1/4 mile times. I have a 360/380 hp crate motor I would like to experiment with the turbo deal. THANKS.....
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Soooooo close to the 9's!!!!! [Re: D-50] #1490199
08/28/13 09:19 PM
08/28/13 09:19 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Soooooo close to the 9's!!!!! [Re: pittsburghracer] #1490200
08/28/13 09:43 PM
08/28/13 09:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
http://cochise.uia.net/pkelley2/eight-to-quarter.htm
You really cant use those tables with a turbo car..
they tend to be soft on the front half but come on big
on the top end
Re: Soooooo close to the 9's!!!!! [Re: pittsburghracer] #1490201
08/28/13 09:58 PM
08/28/13 09:58 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
According to that site my truck runs around 9.90 in the 1/4. I had know idea. Thanks...
Re: Soooooo close to the 9's!!!!! [Re: D-50] #1490202
08/28/13 10:12 PM
08/28/13 10:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
As a good multiplier for a N/A set up... multiply
your 1/8 by 1.57
Re: Soooooo close to the 9's!!!!! [Re: MR_P_BODY] #1490203
08/28/13 10:32 PM
08/28/13 10:32 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Re: Soooooo close to the 9's!!!!! [Re: dizuster] #1490204
08/28/13 10:52 PM
08/28/13 10:52 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Thanks, if you could get your 60 ft. better you would run nines easy. I know turbo cars run better on the top end. You should look into getting it a little lighter it would really pick up.I know that is easier said than done.Thanks..
Re: Soooooo close to the 9's!!!!! [Re: D-50] #1490205
08/28/13 11:58 PM
08/28/13 11:58 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
How about a Dana 61? They used those in the first gen Cummins trucks equipped with a 727, they had a 3.07 ratio
Re: Soooooo close to the 9's!!!!! [Re: WO23Coronet] #1490206
08/29/13 12:38 AM
08/29/13 12:38 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I thought Ford had a 3.33 gear they used in Dana 60's in half ton Vans at some point to.
Mopar to the bone!!!
Re: Soooooo close to the 9's!!!!! [Re: WO23Coronet] #1490207
08/29/13 03:01 PM
08/29/13 03:01 PM
IL
furious70 Offline
furious70  Offline
IL
finding one of those would be difficult these days, but if you could find one of those early cummins/727 trucks you could rob the rear end and still probably sell it for what you paid, and most people want those trucks for conversion uses.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Page 3 of 3 1 2 3
