05 dakota idle problem #1490001
08/24/13 08:55 PM
08/24/13 08:55 PM
Eastern ohio
Alexdodge Offline OP
Eastern ohio
Recently the idle on the dakota has been varying up and down, up and down whenever its in park or sitting at a traffic light. Doesn't matter if its hot or cold. Just moves between 700 and 1100 rpm. Need some ideas where to start looking or changing.
Thanks, alexdodge
Re: 05 dakota idle problem [Re: Alexdodge] #1490002
08/24/13 09:10 PM
08/24/13 09:10 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Check the battery first.Have a load test done as a weak battery creates all kind of problems with them.The IAC might need cleaned and or the EGR also and the throttle plates.Is the check engine light on?Rocky
Chrysler Firepower
Re: 05 dakota idle problem [Re: therocks] #1490003
08/25/13 10:51 AM
08/25/13 10:51 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Had the same issue with my '96 Dak 3.9...pulled and cleaned the IAC valve, ran perfect after that. It mounts on the top rear of the throttle body with a couple of Torx head screws. Here's a shot of an old one.
Re: 05 dakota idle problem [Re: vdriver] #1490004
08/27/13 10:25 PM
08/27/13 10:25 PM
Eastern ohio
Eastern ohio
I'll check out this IAC unit on thursday. Thanks, Alex
Re: 05 dakota idle problem [Re: Alexdodge] #1490005
08/28/13 12:14 AM
08/28/13 12:14 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Also make sure the TPS has a steady voltage reading. I had many with a bad TPS do that. Many times when the idle flucuates its becaue something is telling the PCM to move the IAC motor. When the TPS volts changes at idle the PCM thinks you steped on the gas and will bring the idle up some. Ron
