70 340 vs 95 360 Engine mounts and brackets question #1489953
08/24/13 03:51 PM
08/24/13 03:51 PM
McHenry, Illinois
RAUPLEMINZE454 Offline OP
McHenry, Illinois
Hey guys,
About to mount the engine to the K frame and install the drive train from the bottom. Before I started I just wanted to make sure that the 1970 340 brackets and rubber mounts would still work for a 1995 360 magnum? It appears that they will I just wanted to get some feedback.
I was also wondering if anybody had pictures of how the brackets attach to the block? I am wondering what side of the casting the brackets get bolted on to?
Thanks in advance,
Brian
Re: 70 340 vs 95 360 Engine mounts and brackets question [Re: RAUPLEMINZE454] #1489954
08/24/13 08:46 PM
08/24/13 08:46 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The Magnum blocks use 340-360 brackets
Re: 70 340 vs 95 360 Engine mounts and brackets question [Re: BulletBob] #1489955
08/25/13 07:11 AM
08/25/13 07:11 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
steel brackets go on the rear of the ears on block
