Help with engine ID
#1489935
08/24/13 03:48 PM
08/24/13 03:48 PM
Posts: 1,400 canada
jneuf
canada
Stumbled upon an old mopar with a big block and my mind blanked while trying to ID the engine...
Car in question is a '65 sport fury convert, factory big block car. My impression is the big block engine options available were the 426W, and 383 2bbl & 4bbl....and all would have been turquoise, correct?
The only numbers I could get at were on the ID pad located on the driver side of the engine, leading me to believe it's not a 383 (only the RB engines had their ID pad on the front driver side of the block, in front of the intake manifold, right??).
I've attached a couple pics...including the ID pad, the carb ID tag, and the whole engine.
I'm thinking it might be a swapped in 413..??
Re: Help with engine ID
[Re: jneuf]
#1489936
08/24/13 03:48 PM
08/24/13 03:48 PM
Posts: 1,400 canada
jneuf
canada
[Re: jneuf]
#1489937
08/24/13 03:49 PM
08/24/13 03:49 PM
Posts: 1,400 canada
jneuf
canada
[Re: jneuf]
#1489938
08/24/13 04:32 PM
08/24/13 04:32 PM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
361 was also available in a 2bbl only version in 1965. All B and RB engines were turquoise. The 318 would have been red. Sport Furies had the 318 2bbl as standard equipment.
This is the land of the free
because of the brave
[Re: 300rag]
#1489945
08/24/13 08:55 PM
08/24/13 08:55 PM
Posts: 1,400 canada
jneuf
canada
If this is a Canadian built car then I believe all engines were red. I can't remember which year they changed, but 64's were still all red.
Had not heard that before. Interesting!
I know they did some whacky things on Canadian built cars...This color looks like the same red that's on my '65 318 poly. So no matter the engine size, were they doing all engines red?
[Re: jneuf]
#1489946
08/25/13 10:33 AM
08/25/13 10:33 AM
Posts: 1,791 Big Sky Country
MO_PA
Big Sky Country
Does it have a pcv valve or a draft tube, I've seen numbers similar to those on red engines from early CBody cars and Imperials.
It could be a RB 350cid
[Re: MO_PA]
#1489949
08/26/13 11:27 AM
08/26/13 11:27 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Crawl under it and see what the cast numbers are.Should have them on the block and say the date and size.Rocky
Chrysler Firepower
[Re: Rug_Trucker]
#1489951
08/26/13 01:36 PM
08/26/13 01:36 PM
therocks
Niles , Ohio
I think the 350 was just a B block.I had one in a 59 Fury that it wasnt supposed to be in.It was all OE and an early order car.I guess it was a left over.I was the third owner and the original buyer never touched it since new.A guy I went to school with had it 2nd and he never touched it either.Sold it to a guy that bought my 47 Ford coupe as he put it and the 3 speed in it.Rocky
Chrysler Firepower
[Re: therocks]
#1489952
08/26/13 02:01 PM
08/26/13 02:01 PM
dogdays
The 350 was the first B engine. It was followed by the 361, 383 and 400, all dimensionally the same except for bore size.
I believe the 413 was the first RB. The RB383 was a stopgap engine, couldn't keep up with demand on the B engine IIRC. But as much as it gets mentioned here, they are really few and far between. So 413, 383RB, 426, 440 in that order.
DO buy the whole car, for cheap. That engine stamping is indicative of something that may be valuable, may be just an oddity.
But thanks for bringing it to our attention.
If you were REALLY lucky, the cylinder heads wouldn't have soft plugs on the ends.
And whoever would confuse that engine with a Poly needs to go to Remedial Mopar Engine Identification class.
R.
