rocker shaft torque #1489878
08/24/13 01:36 PM
08/24/13 01:36 PM
Q
Quicktree Offline OP
Q
with aluminum(indy) heads. who torques the studs? or do you finger tighten them? I remember years ago with my indy 360-1s I finger tightened them and they backed off in a final round costing us a race. I think I called indy and they said to torque then to 50 ft lbs. but can't remember.
Re: rocker shaft torque [Re: Quicktree] #1489879
08/24/13 02:20 PM
08/24/13 02:20 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I just snug them in
Re: rocker shaft torque [Re: Quicktree] #1489880
08/24/13 02:21 PM
08/24/13 02:21 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
If it's a 3/8 stud, 50# will pull out. I'd locktite them & torque to 35#.
Re: rocker shaft torque [Re: Quicktree] #1489881
08/24/13 06:26 PM
08/24/13 06:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
50# is higher than a grade 8 calls for on torque..
locktite the studs and torque the nut to 30#-35# and
let the locktite set up before you loosen the nut..
I do screw the stud in by hand so its bottomed or
near the bottom for full thread contact
Re: rocker shaft torque [Re: MR_P_BODY] #1489882
08/24/13 07:08 PM
08/24/13 07:08 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
35# on my 440-1 setup with ARP studs.
The little old lady from Pasadena is back!
