Re: Yikes! Look at This Broken Wheel Stud [Re: 340B5] #1489875
08/25/13 03:52 PM
08/25/13 03:52 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I recommend staying away from Moroso wheel studs. They have some kinda coating that flakes off and clogs the lugnut threads up. I had this happen and had to break three studs so I could get my front Weld superlites off. I never experimented with trying to wire wheel that coating off before hand but its there and it blows.
Mopar to the bone!!!
Re: Yikes! Look at This Broken Wheel Stud [Re: cgall] #1489876
08/25/13 04:38 PM
08/25/13 04:38 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Good deal on replacing them with all new ARP or a good quality stud made for the job.
I think your problem stemmed from electrolysis as I see corrosion between the hub and studs and a cheaper made stud?
Use lot's of anti seize when you put the new ones in. May want to consider replacing the lug nuts to be 100%. I know, cost money. Not sure on the lugs, I'd want them to spin on by hand and be snug with no looseness on the new studs.
Here's hoping you can get the old ones out with no problem. Clean all the rust off the studs first so you don't mess up the hubs taking them out. Good luck and good catch.
Re: Yikes! Look at This Broken Wheel Stud [Re: Challenger 1] #1489877
08/25/13 04:45 PM
08/25/13 04:45 PM
Aubrey, Texas
O
oldtimer5151 Offline
O
Aubrey, Texas
