Trans cooler in series? #1489813
08/24/13 06:58 AM
08/24/13 06:58 AM
Kentucky
dfsmopars Offline OP
Kentucky
I bought a 3/4" thick Permanent-cool trans cooler. The instructions say it must be installed in series with the radiator. They do not want the radiator by-passed. I bought a 15 x 7 cooler and planned on installing it between the A/C condensor and the radiator. I would think the size and location of the cooler would work better by-passing the radiator. So, why do they want the fluid running through the radiator and cooler?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Trans cooler in series? [Re: dfsmopars] #1489814
08/24/13 08:04 AM
08/24/13 08:04 AM
SE PA
Yellow Fever Offline
SE PA
The radiator will cool it down first then get it even cooler going through the external one. With a cooler that size it should work fine. Do you have a deep pan? Check with a trans temp gauge.
Re: Trans cooler in series? [Re: dfsmopars] #1489815
08/24/13 09:42 AM
08/24/13 09:42 AM
either for more cooling or I've heard something about the rad coolant warming the initial cold trans fluid which I dont buy as I've never had a trans issue from cold fluid (converter drainback excepted) plus I've had some bottom rad coolers leak antifreeze into the trans lines. I keep em seperate & on a side note the hot line coming from the front of the trans I plumb that to the top of the cooler so the hot fluid is coming in at the top just like the rad. Not a dealbreaker but one of my anal idiosynchrosies. With that much area you'll have no problem. It would be interesting to call or email the company & ask them why they want it that way as they are the pro's regarding their product.
Re: Trans cooler in series? [Re: Yellow Fever] #1489816
08/24/13 09:42 AM
08/24/13 09:42 AM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
It will do a better job running through the rad. and the cooler. My truck has two coolers and runs through the rad. too. I also have a deep trans. pan (also a good idea).
Re: Trans cooler in series? [Re: RapidRobert] #1489817
08/24/13 01:27 PM
08/24/13 01:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
How would you know if you did?
Re: Trans cooler in series? [Re: Yellow Fever] #1489818
08/24/13 07:56 PM
08/24/13 07:56 PM
Kentucky
Kentucky
The trans does have a deep pan. Where do I install a sensor for a gauge? This is an A500 in a third gen b body.
Just asking- If an engine is runnIng 180* what is the temp of the fluid going through the bottom of the radiator? How much does it drop the temp of the trans fluid in a normal situation?
The reason for the questions is because I am installing a small stall converter so I know it is going to generate a little more heat.
Re: Trans cooler in series? [Re: dfsmopars] #1489819
08/24/13 09:08 PM
08/24/13 09:08 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..isn't the trans cooler in the rad really a "heater"?
passing trans fluid through a 180 degree rad will warm it for cool weather operation and the experts i have talked to want your trans operating 170 - 190 degrees.
a big cooler not plumbed through the rad might keep the transmission t too cool?
i have a dynamic 9 1/2 converter and a 5 x 11 trans cooler and have
a hard time keeping the trans above 160.
...i should have run mine through the rad.
Re: Trans cooler in series? [Re: John_Kunkel] #1489820
08/25/13 09:33 AM
08/25/13 09:33 AM
If the trans was acting up when cold & straightened out when hot or if I became convinced that cold fluid was shortening its life over the long run but if using the rad cooler for the heat benefit is the way to go I will go with that as you are the man
Re: Trans cooler in series? [Re: RapidRobert] #1489821
08/25/13 10:08 AM
08/25/13 10:08 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I cannot think of one OEM manufacturer that agrees with your theory. But you know best.
You do not want a cold transmission, you want a transmission with a stable temperature of 175 to 200 degrees. Too cold or too hot are both bad.
Don't be the exception.
Re: Trans cooler in series? [Re: Supercuda] #1489822
08/25/13 11:06 AM
08/25/13 11:06 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The factory service manual for my 92 D250 says the overdrive will not engage until the transmission has reached a specified temperature.
That tells me they don't want the transmission too cool.
- Stu Harmon
Re: Trans cooler in series? [Re: feets] #1489823
08/25/13 11:37 AM
08/25/13 11:37 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Anytime I have ran a large tranny cooler, I have thought that the tranny took a long time to come up to temp and ran a little cool unless I was flogging it. I even picked up an engine oil thermostat to plumb in the lines, but the bypass was so large that the cooler got full flow all the time.
So, I just run a smaller tranny cooler now. But it is slow to bring the temps down when I am beating on the car.
Other than the tranny coolers with fans and temp switches to trigger the fan, is there any such thing as a thermostat for our tranny cooler lines? Seems that would make sense. Bring the temp down quick or not let it get too high to begin with, while not running the tranny too cool under light loads. Would bring it up to temp quicker, too.
Obviously a street/strip application.
Master, again and still
Re: Trans cooler in series? [Re: DaveRS23] #1489824
08/25/13 11:52 AM
08/25/13 11:52 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Re: Trans cooler in series? [Re: Supercuda] #1489825
08/25/13 12:12 PM
08/25/13 12:12 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Exactly what I have been looking for. Thank you!
Has anyone ran this? Worth the trouble?
Re: Trans cooler in series? [Re: DaveRS23] #1489826
08/25/13 03:15 PM
08/25/13 03:15 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
The friction characteristics of trans oil are temp dependent, and I suspect there is an optimum preferred temp range, and by running thru the rad, the aftermarket cooler vendor also escapes some liability of over cooling the trans fluid.
Re: Trans cooler in series? [Re: dfsmopars] #1489827
08/25/13 03:52 PM
08/25/13 03:52 PM
Kentucky
Kentucky
OK, I think the first bit of business is to buy a B&M gauge kit from Summit and just see where the trans is right now, what happens when the converter is in and go from there.
Re: Trans cooler in series? [Re: RapidRobert] #1489828
08/25/13 04:40 PM
08/25/13 04:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Ask any fluid supplier and they'll tell you that the ideal minimum fluid temperature is 160°F...there is zero benefit to running it any cooler.
Re: Trans cooler in series? [Re: John_Kunkel] #1489829
08/25/13 04:56 PM
08/25/13 04:56 PM
JK Your sayso is good enough for me. Actually the only reason I dont run one is I had several of em (in a row) leak so I just started bypassing them & running a large external cooler & calling it good. Also I just figured that since I wouldn't be jumping on it till the eng was warmed up that the trans staying cold slightly longer without the OE cooler to warm it wouldn't be causing any damage to the trans
Re: Trans cooler in series? [Re: John_Kunkel] #1489830
08/25/13 06:44 PM
08/25/13 06:44 PM
I had a Cyberdyne digital trans temperature guage on my 1998 CTD 2500 Ram with the towing package, the tranny temps. never exceeded 130 F, normally cooler than that , when not towing, summer or winter in the Mojave deserts It would get up to 220 F when towing up a long grade(18 mile long Baker grade going to Las Vegas) at 70 MPH with the enclosed car trailer loaded to 8200 Lbs with the race car in it, I would lock it out of overdrive at the bottom of the hill and unlocked once it went over the top of the grade The tranny temps would go back down to 160 F in around five miles of coasting down that hill or on the flats when towing in the summer heat, 117 F outside air temps at 3.00 PM in Baker,CA in July and August
Re: Trans cooler in series? [Re: Cab_Burge] #1489831
08/25/13 06:55 PM
08/25/13 06:55 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I assume the truck had only an air to air trans cooler?
Re: Trans cooler in series? [Re: Cab_Burge] #1489832
08/25/13 07:12 PM
08/25/13 07:12 PM
Groveland, MA
SteveS Offline
SteveS  Offline
Groveland, MA
When Ford started separating all of their transmission coolers, and making them completely independent of engine cooling, they added thermostatic bypasses to them. Depending on the platform, they can be within the cooler, inside the transmission, or in a block in between. As an example, ALL '98-up Panther platform cars (Crown Vic, Grand Marquis, Town Car) had a separate cooler with a 180°F thermostat and a bypass within the cooler. The same cooler assembly also housed the power steering cooling circuit.
The went to the added expense of the thermostatic control both for cold weather drivability and for transmission longevity.
At any rate, they are great coolers, and there are a gazillion of them in junkyards everywhere.
Steve
Someday I'll have another C-body.
