Re: 971 Pan Capacity
[Re: 65Fury440]
#1489490
08/25/13 04:46 PM
08/25/13 04:46 PM
Posts: 25,998 Rio Linda, CA
John_Kunkel
Rio Linda, CA
There seems to be some confusion about the actual pan capacity, some pans advertised as being a "five-quart pan" actually hold only four quarts but the whole system (including the filter) holds five quarts.
[Re: screamindriver]
#1489492
08/25/13 09:53 PM
08/25/13 09:53 PM
RapidRobert
If it IS actually a 4 qt sump I'd verify that & put 4 qts in on a level surface & mark the stick at that point. The sump level is what is important
