Re: what size winch are u using in your enclosed trailers?
[Re: gtsuperbee]
#1489395
08/23/13 12:49 PM
08/23/13 12:49 PM
dartman366
Mt. Vernon, Ohio
I have a 2500# superwinch, it's adequate (my car is a little less than 2900#) but I wish had a 3500#, I just got such a deal on mine that I give it a try, been in the trailer since I bought it in 2001, I would go with a 3500# minimum if I were to do it again.jmo
[Re: Jeepmon]
#1489399
08/23/13 02:58 PM
08/23/13 02:58 PM
Posts: 19,376 Las Vegas
Al_Alguire
Las Vegas
I have a Warn S4000, been very happy with it. I have also in the past used the small ATV winches out there. They work ok and with a snatch block will work even better, doubling thier capacity. Keep in mind the weight rating on a winch is supposed to be the weight it can pick up vertically, not pull horizontially. While a smaller one will not be as fast as something larger with a snbatch block and a small ATV winch you shoudl have no issue, unless you are in a huge hurry to pull it in the trailer.
[Re: Al_Alguire]
#1489400
08/23/13 03:14 PM
08/23/13 03:14 PM
dartman366
Mt. Vernon, Ohio
I fully agree with this, thats why mine has not been replaced yet, when/if mine ever go's bad thats when I will upgrade to somthing with a little more capacity.
[Re: Dragula]
#1489402
08/23/13 10:49 PM
08/23/13 10:49 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Mile marker 4500 love it.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Quicktree]
#1489405
08/24/13 12:26 PM
08/24/13 12:26 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Superwinch S-4000 here.......... seems to work just fine for my needs. Also have a Superwinch S-4500 and they have re-rated that model to the S-5000 now. Bought it before I had the enclosed trailer and wouldn't you know I ended up with a trailer that already had a winch. It's used, works, complete and is for sale if you have an interest send me a PM I can send you some pics
[Re: gtsuperbee]
#1489407
08/26/13 12:23 AM
08/26/13 12:23 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I have a cheapo HF 1500 thats on my open trailer.. I have a cheapo HF 2500 in my enclosed trailer... I use to winch my car in backwards all the time with the 1500(about 3 years) till the clutch started to slip some then I got the 2500 but have never used it in my trailer... I did drag Labrats B-body (GTX)on his trailer with it.. no problem at all.. Understand that the pounds rating on them is for a vertical lift so MOST guys are WAY over whats needed
[Re: rickb67]
#1489408
08/26/13 08:18 AM
08/26/13 08:18 AM
Posts: 34,928 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Matt that bulldog 4500 works great. I love it
Yep, those are great !
