Elect. Fuel Pump recommendations #1488513
08/21/13 07:33 PM
08/21/13 07:33 PM
pensacola, fl
53fopar Offline OP
53fopar  Offline OP
pensacola, fl
Well the old Mopar fuel pump gave up today. Guess it's time to go electric. It's a 1977 360 with stock heads. Edelbrock 1405, Summit high rise intake, Headman headers, stock dist. with pertronix. Just a street truck.
What's recommended for a elect. in-line pump?
Re: Elect. Fuel Pump recommendations [Re: 53fopar] #1488514
08/21/13 08:17 PM
08/21/13 08:17 PM
dogdays Offline
dogdays  Offline
Carter P4070 is what I recommend to any who'll listen.
R.
Re: Elect. Fuel Pump recommendations [Re: dogdays] #1488515
08/22/13 11:10 AM
08/22/13 11:10 AM
Endicott, NY, USA
crazyjjk Offline
crazyjjk  Offline
Endicott, NY, USA
Another vote for the Carter. Running the carter on my 37 Dodge with a 360 in it. No problems with it so far.
Re: Elect. Fuel Pump recommendations [Re: crazyjjk] #1488516
08/22/13 10:48 PM
08/22/13 10:48 PM
pensacola, fl
53fopar Offline OP
53fopar  Offline OP
pensacola, fl
How much noise does that Carter make? I've heard some guys and their electric pump sounds like an outboard motor.
Re: Elect. Fuel Pump recommendations [Re: 53fopar] #1488517
08/23/13 01:08 PM
08/23/13 01:08 PM
dogdays Offline
dogdays  Offline
You do have to use the rubber mounts. You can hear it when you turn the key on, I can't hear it when the engine starts and I'm running a Dynomax Hemi Super Turbo which is louder than stock but not a Flowmaster.
Looking in my latest Summit catalog I see an Edelbrock pump that's supposed to be a lot quieter than your average electric pump. You could try that, I suppose. But the Carter is quiet enough for me. I'd definitely buy another.
R.
Re: Elect. Fuel Pump recommendations [Re: dogdays] #1488518
08/23/13 10:29 PM
08/23/13 10:29 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
I have used noisy pumps in the past and didn't like it. When I was shopping for my current pump, I was looking for something quiet. I settled on a Holley 12-125. It is very quiet, don't hear it at all with the car running.
Re: Elect. Fuel Pump recommendations [Re: B1arno] #1488519
08/29/13 10:50 PM
08/29/13 10:50 PM
pensacola, fl
53fopar Offline OP
53fopar  Offline OP
pensacola, fl
Thank guys. Went with the Holley 12-125. Silent. Have to turn off the electric fan to hear it at all. Puts out 6 1/2 psi which is just right for the Edlebrock carb.
Re: Elect. Fuel Pump recommendations [Re: 53fopar] #1488520
08/30/13 12:27 AM
08/30/13 12:27 AM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
Re: Elect. Fuel Pump recommendations [Re: B1arno] #1488521
08/30/13 03:22 AM
08/30/13 03:22 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
my opinion,,,i would never rely on an electric pump that is not in the tank,,they over heat and quit PERIOD,, (and i have a elec carter on my early hemi,not my doing cant be reversed) i would go with a carter mechanical pump, since you have a stock motor a stock carter replacement is still better then any auto parts store pump,,,i ran a carter 120 gph 7 psi mechanical pump for 12 years on the street on a blown 340 dual quad motor,,only reason i changed it was i freshened up a few things and did some cleaning,,,,just my 2 cents,,,probably worth 1/2 cent these days,,,lol
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Elect. Fuel Pump recommendations [Re: fstfish66] #1488522
08/30/13 02:24 PM
08/30/13 02:24 PM
dogdays Offline
dogdays  Offline
I am still running the same Carter "strip" electric pump I installed back around 1984. It has never failed me. PERIOD.
It hangs proudly in the breeze under the car, it operates after sitting for more than a year full of fuel, Mmy only wish is that the hot rod shop in Cheyenne, WY would have had a "street" pump in stock the day we rolled in off the Interstate and bought this one, installed it in the parking lot. Because it's a strip pump I have had to use a regulator.
I've bought others of this configuration, used, for pennies and never had one fail. They even make a 6 volt model for your old iron!
If you can get a tank mounted pump it'll be better, or if you have an extra $800 you can buy the Aeromotive kit that is really slick. But if you need to get fuel to the front of the car that Carter'll work.
R.
Re: Elect. Fuel Pump recommendations [Re: dogdays] #1488523
08/30/13 03:06 PM
08/30/13 03:06 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
R.
nice that some one has all the luck,,,carter is now fedral moguel,,they make the electirc fuel pumps (lift pump) for the dodge cummins trucks,,they are junk,,ask any one that owns a 1998 to 2002 dodge cummins,,,i have an extra on hand all the time,,,,stock truck,no power adders or hand held tuner,bone stock,,truck has 115000 on it,, im on my 5th carter elect fuel pump,,,, i have now moved it close to the tank see how long this one lasts,,, last one had 9000 miles on it,,
2015 cherokee
2013 R/T classic
Re: Elect. Fuel Pump recommendations [Re: fstfish66] #1488524
08/30/13 04:15 PM
08/30/13 04:15 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I bought an electric fuel pump from NAPA 10 years ago (maybe longer) on my 4x4, one of those little square ones. The thing was flawless before the truck got wrecked, I used the pump to pump out 3/4 of a tank of gas before the truck went away. Probably should have pulled the pump too.
Every old Mopar I've had since about the early 80s has had an electric pump on it. In all those years, only one pump has failed, and that was just after a gas stop on the road, and there was pieces of crud stuck inside the pump and the pre-pump filter was nearly plugged. I replace the filter and the pump, then a couple hundred miles later I replaced the filter again, (Again it was full of crud, by the 3rd filter everything was good). I carried a replacement pump and filter along with the extra ignition box in a parts box I took everywhere I went. I have used those parts to help other people get home with their cars, but have not ever needed them myself.
Mounting near the tank, below the bottom of the tank, with the outlet end higher then the inlet has worked well for many years. I've not ever had one I could hear over a running car, but then again, most of my stuff isn't real quite. Gene
